RV.Net Open Roads Forum: Travel Trailers: Green Valve Stem Covers
 > Green Valve Stem Covers
ktmrfs
Portland, Oregon
Posted: 12/21/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Since O2 and the rest bleed out so quickly virtually all tires have just Nitrogen. Molecules are the same size so it must be some voodoo power of the green cap.
well oxygen molecules are slightly smaller than nitrogen, even though atomic weight is higher. So tires will loose slightly less pressure but not much. And with todays tire construction it would take a LONG time before all the oxygen bleed out.
Really all a dry nitrogen fill does is eliminate water vapor which can go from gas to liquid and have a bigger pressure change effect. For those us where a few PSI is no big deal, no problem. Could do basically the same thing with plain dry air. All gases obay boyles law for pressure vs. temperature.
2011 Keystone Outback 295RE
time2roll
Posted: 12/21/20 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry I forgot to add the winker to indicate sarcasm [emoticon]
675w Solar pictures back up
Posted: 12/21/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
The green stuff is the magic gas!
2017 Heartland Torque T29
mobeewan
Hampton, Va
Posted: 12/22/20 01:33am Link  |  Quote  |  Print  |  Notify Moderator
Helium and hydrogen are way better. They will even make the trailer a few pounds lighter. Hydrogen will give the best BANG for your money.
BurbMan
Noblesville, IN
Posted: 12/22/20 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Be sure to also check your blinker fluid before you hit the road [emoticon]
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Diamond c
West ky
Posted: 12/22/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I installed an oversized blinker fluid reservoir so I con leave it on for lots of miles.
Near DVNP, California
Posted: 12/22/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
"Helium and hydrogen are way better. They will even make the trailer a few pounds lighter."
How many pounds? lol
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mr_andyj
Georgia
Posted: 12/22/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
HAHA, NO!
No, a green cap means nothing.
Slime used to give green aluminum caps with their Slime sealant product. It is green because their slime and their logo is green.
I do not think nitrogen has a color, and am sure if it did that green is not the color.
You can get plastic or anodized aluminum colored caps in almost any color now. What do all those colors mean? Nothing. The pope's red shoes do means something, but unless you want to vomit I would not look into that....
time2roll
Posted: 12/22/20 11:03am Link  |  Quote  |  Print  |  Notify Moderator
I quite frankly prefer my OEM black caps.
Nitrogen or air they can fill as they like and I will ignore and top off as needed with regular compressed air.
Lynnmor
Red Lion
Posted: 12/22/20 11:04am Link  |  Quote  |  Print  |  Notify Moderator
You really should replace the green valve caps with black ones, it might keep others from asking useless questions.
