RV.Net Open Roads Forum: Tow Vehicles: New Truck Buyer Needs Help
Search only in Tow Vehicles
 > New Truck Buyer Needs Help
Texsinbad
Posted: 12/22/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
In the process of buying a Rockwood 2205S trailer, UVW 5004# CCC 1686# for a total of 6690#. Now, I need to buy a tow vehicle—properly equipped half-ton truck.
Not being mechanically inclined, I usually buy new for the warranty, but new prices for trucks are too high for me. I doubt that I could find anything less than $37,000.
For that reason, I am looking for used in the $20,000 range, but not being a “truck” person, I am not sure where or how to look. I have looked on Craigslist, carmax and other internet sites, but not sure how to make sure that I find a truck that has the capability to tow.
For instance, how do I know what the axle ratio is?
Any comments/suggestions for a new truck buyer would be appreciated.
Thanks
agesilaus
North Florida
Posted: 12/22/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
You can plug the truck's vin number in a decoder and get a lot of info on it, not sure about the axle ratio tho: Edmunds
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Diamond c
West ky
Posted: 12/22/20 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Go to a dealership and buy a used truck. They should be able to tell you everything about it, and you might get a little warranty to boot.
ACZL
UPstate,NY
Posted: 12/22/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Are you serious? A dealer just just wants to make a sale, UNLESS a GOOD dealer actually knows something about towing. Years ago a local dealer tried to tell me a Ford Ranger w/ 4.10 gears will tow a house. What OP needs a truck w/a tow package and like 1st reply said, plug in the VIN to see how it's equipped from factory. Just because it may have a hitch on it does not mean it's set up for towing.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
kellem
Shenandoah valley,VA
Posted: 12/22/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Keep it simple for starters.
Payload is always the determining factor with half-ton trucks.
Look for the GVWR of trailer, usually stamped on driver's side front of trailer. Take 12 - 15% of this weight as trailers tounge weight.
Now go to the door sticker on truck and find payload CCC.
Deduct the trailers tounge weight, all passengers weight and cargo that you plan to carry on truck from the trucks rated payload and see where you stand.
If you plan to upgrade trailer in future like so many do then it would be prudent to look at 2500 - 250 series trucks.
Sjm9911
New Jersey
Posted: 12/22/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Look for one that has a tow package allready. That should give you some upgrades you may need plus some wireing will allready be in place for the camper.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
ShinerBock
LVTX
I believe all of the half ton truck makes offer a truck that can tow that under $37k. It may not be a 4wd with all the bells and whistles though.
OP, look at the window sticker or "monroney" label as they call it. Look for things like tow package or trailer tow package and make sure it has the proper axle rating, wiring, and receiver hitch for towing. If it has a N/A(naturally aspirated) V8 or a turbocharged 6 cylinder, then it will be able to tow what you have. I would not recommend a N/A V6 or turbocharged 4 cylinder for your trailer.
The more gearing the transmissions has, the less relevant the rear axle ratio. Turbocharged engines can also get away with taller gear ratios(lower number) than N/A. For example, the 3.55 on my old turbocharged 3.5L Ecoboost work truck pulled the same loads better and had a higher tow rating than the N/A 5.0L V8 with a 3.73 I had before. In my opinion, I would not go lower than a 3.55 on a turbocharged gaser and no lower than a 3.73 on a V8 within that price range.
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
Monterey, California
Posted: 12/22/20 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Don't take anyone's word for max tow weight, tongue max weight or payload. Look at the sticker...take a picture of it. Study it alone...without a salesman. You'll need 900+ pounds of payload for that TT plus people and stuff in the truck IMO.
LIKE2BUILD
Decatur
Posted: 12/22/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Not quite. Many car sales people don't know much at all about towing capacities, especially if it's a used truck that is not the dealership's brand. Case in point, a friend went to the local Ford dealer to get an F150 with the max tow rating. He drove away with a 4x4 F150 that had no OEM brake controller and a 5.0 V8. The 3.5L EcoBoost had the max tow rating that year but the sales person convinced him that "big V8 engine will tow anything".
This is not the first story on this forum about sales staff not knowing squat about tow ratings and packages.
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
Boomerweps
Hills of PA
Posted: 12/22/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Look for a truck with a factory hitch receiver and a 7 pin connector NOT mounted to the hitch. Look for a factory Trailer Brake Controller. That will tell you it was bought set up for towing. Rear axle ratio can be determined by the axle code on the white sticker on the driver door frame. Also it’s GVWR. Look at the yellow sticker for Load Capacity. If it’s a GM from the last few years, they actually have a tow capacity sticker!
I recommend finding a truck or two you think might work, take photos of those door stickers, and use them for some online research. The meaning of each of the codes on the white federal weight sticker can be found in the online owners manuals. There are some posts on the F150 forum on how to get the factory window sticker for a given Ford truck.
Keep in mind the more options or upper level trim series, the more you lose truck payload and with that tongue weight carrying. So be mindful of those yellow stickers.
Let us know what you find, plenty of free opinions here [emoticon]
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
