RV.Net Open Roads Forum: Travel Trailers: Greasing the hitch
 > Greasing the hitch
Rover_Bill
NE. Ohio
Posted: 12/22/20 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
The Eaz-Lift ReCurve R3 and R6 require both a greased ball and a shot of grease on the shaft. The R6 also requires grease on the sway control bearings.
2015 GMC Canyon 3.6L V6 4X4 TowHaul SLE ExtCab Bronze
2016 Keystone Passport GT 2670BH
ReCurve R6 hitch, DirecLink brake controller
2005 Suzuki C50 2006 Suzuki S40
Dick_B
Palos Heights, IL USA
Posted: 12/23/20 08:23am Link  |  Quote  |  Print  |  Notify Moderator
I use several layers of wax paper on the ball. No grease on pants or other things but lube everything else with a high pressure grease (red) that is used with a grease gun. One tube will last a lifetime.
* This post was edited 12/23/20 08:31am by Dick_B *
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
TravelinDog
Nevada
Posted: 12/23/20 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Now that's funny $10 bucks for 3.2oz.of genuine "Reese hitch lube".
It always amazes me how much people over-think such simple things. If there is metal to metal contact and it's going to move then yes is should have some grease, ANY KIND of grease.
Family-of-five
Cardale Pa
Posted: 12/25/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I put a dab of grease on the ball and spring bar points everytime I hook up. Cheap automotive wheel bearing grease is all you need 3 bux for a big jar
jerem0621
Tennessee
Posted: 12/26/20 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yes and I just use grease from my grease gun.
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
Vintage465
Prunedale CA.
Posted: 12/26/20 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I think it is wise to grease the friction points at the pivots. I used to keep a little tub of wheel bearing grease in the pass thru to grease the hitch ball and the rub points of the W.D. bars. Lately I've found that a little tube of white grease that is smaller than a tube of tooth paste lasts a long time and way less messy to deal with.
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
BarneyS
S.E. Lower Michigan
Posted: 12/27/20 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Any time you have metal to metal contact with friction you are going to have wear. The idea of the grease is to reduce that friction and therefore the wear.
Almost every single hitch manufacturer, with the exception of one (Andersen) that I am aware of, recommends the use of some type of grease on the tow ball. There have been instances of people not using grease and hitch ball came loose in the head because of the friction and turning motion during turns.
In addition, if you have L shaped WD bars that insert up into the hitch head you should grease those bars every time you tow. There is a tremendous amount of pressure between those bar ends and the hitch head receptacles. Dry bars will often make a lot of squeaks and grinding noises. Over time, the bars ends will wear into an oval shape and the inside of the hitch head will wear quite badly on the bottom edge closest to the trailer. When this happens, you will get less and less WD from your bars and find you have to take up another link or adjust the bars up tighter. This is a clue that your bars are wearing out. Contrary to what was implied in a previous statement - a hitch head or WD hitch does not last forever.
I used to remove my bars at the end of a towing session and wipe them off along with the ball before stowing away. Then I would apply a light coating of wheel bearing grease before every new tow.
Did this routine for over 50 years until stopping towing recently. Always worked for me! [emoticon]
Barney
Not towing now.
snowedin
Poverty Flats, MT
Posted: 12/31/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Have been using the double layer of wax paper for years, for better or worse maybe but the wax paper is some slippery stuff and never get grease on my pants. In the 40+ years before I started using wax paper I used nothing, no grease, no anything, just kept the components clean.
* This post was edited 01/01/21 05:03pm by snowedin *
tomman58
Southeast Michigan
Posted: 12/31/20 07:37am Link  |  Quote  |  Print  |  Notify Moderator
I also use tube of lithium grease. The small opening on the end lets you put the grease where it is needed. When we do our final set up after about 6000 miles of towing I use plenty of paper towels and some WD40 to clean up before our next run.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
2112
Posted: 12/31/20 08:57am Link  |  Quote  |  Print  |  Notify Moderator
I've used the same tube of Lucas Red & Tacky #2 for years. Easy to apply without a gun, I used chop sticks. Wiped it off after each trip.
2013 KZ Durango 2857
