biggjb
ottawa
My truck camper has the Dometic rm3663 fridge. Last year there was a short in light switch within the fridge when the door is open. I could not find a replacement so I just kept the switch taped down. No light but no further short either. Now I cannot even turn the main power on without the circuit breaker going off. I have tried to turn it on and then switch from AC to DC but nothing works. I cannot switch to LP either. When I do turn on the power there is a funny noise near the bottom back of the fridge. I have downloaded the wiring diagram and service manual but am not sure where to start. I understand the main power should be DC but could it be anything else.
enblethen
Moses Lake, WA
Yes, It could be failed circuit board 120 volt relay.
Unplug refer in the outside access. Problem should go away. Then inspect circuit board.
If circuit board is bad, replace with Dinosaur Electronics version.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
AnEv942
CA
I would start by unplugging the light power wire at control board, J2.
Puzzling that it would short only when light on because the power wire to it is always hot? switch closed only grounds the bulb...
Not the problem though may have caused it (or still). As far as house power unplug the fridge verify 110 wiring/receptacle good.
Then its testing..manual http://bryantrv.com/docs2/docs/servtips.pdf
has some limited testing you can do.
Our camper projects page
Old-Biscuit
Verde Valley
AC Circuit breaker for fridge is tripping when you turn Fridge ON????
DC is for the fridge controls. display and functions
AC is ONLY for the AC Heater Element
SO it sounds like you have TWO issue
One with the AC Power from CB to Circuit Board (Outlet. fridge power cord, j5/j6 terminals on circuit board
One with DC Power on the circuit board.....which controls all functions
US NAVY------USS Decatur DDG31
biggjb
ottawa
thanks for all the tips. I unplugged the 120v then turned the power back on and DC breaker tripped. I then turned it off and also turned of the climate control switch as well. Turned it back on and the shorting sound stopped and the control lights came back on but the DC control light flickered. After Christmas I will take the cover off the lower circuit board and start testing the fuses and the others suggested.
My trouble all started with that interior light.
enblethen
Moses Lake, WA
What DC circuit breaker?
Old-Biscuit
Verde Valley
DC Breaker..........that sure makes a difference in diagnosis
AC breaker vs DC breaker
TWO totally different electrical systems
You need to start with that bad interior light ---DC Circuit
Re-Read 'AnEv942' post from yesterday
J2 is DC+ for the 'heater cable' the 'Light' and the 'Low Ambient Temp'
edited 12/24/20 10:15am by Old-Biscuit *
biggjb
ottawa
Thanks Old-Biscuit,
I disconnect the wires for J2 and the fridge works, however, the 20A fuse on the DC circuit board still lights up. Both the AC power is good at J5 and J6 are good and the proper DC voltage 13V is at J4. I did notice that the previous owner removed the DC heater element as there is nothing connected to J1. Does anyone know where I can get a replacement 12v heater element?
enblethen
Moses Lake, WA
I would not be using 12 volt element as it will eat battery. So I would not be installing new element.
If you want to, try ebay.
NRALIFR
Truck Camping Out West
A couple of years ago when I thought I needed a new DC heating element for my RM3663, I found that they were out of production and unavailable. IIRC it’s a 215 watt element, and I found a parts dealer that had an element they claimed was a suitable substitute for it. I bought it, noted that it was about 25 watts “hotter” than the OEM, and installed it.
Ran it overnight to make sure it was good, and it appeared to be working ok. When I got up in the morning, the fridge was warm, and when checking the DC fuse I found that the fuse was good, but the fuse connectors soldered to the Dinosaur control board had gotten hot enough to blacken the board around them. I returned the new element for a refund.
![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
2001 Lance 1121 on a 2016 F450
