RV.Net Open Roads Forum: Truck Campers: Dometic RM3663 Fridge
 > Dometic RM3663 Fridge
AnEv942
CA
Posted: 01/14/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
biggjb wrote:
Thanks Old-Biscuit,
I disconnect the wires for J2 and the fridge works, however, the 20A fuse on the DC circuit board still lights up. Both the AC power is good at J5 and J6 are good and the proper DC voltage 13V is at J4. I did notice that the previous owner removed the DC heater element as there is nothing connected to J1. Does anyone know where I can get a replacement 12v heater element?
As to the 12 heater will be tough to find- its not being hooked up would have no effect on fridge working (or not) on gas or AC. IF its still there you can test ohms to see if good.
The indicator on fuse panel lit up, on P/D replacement converter fuse board- fuse pilots should only come on if fuse blown or removed?
I looked at older thread that shows your converter. Noted 20 amp fuse, mine is 30 amp for fridge but I also noted its on fuse slot #1. I doubt have any effect on issues but on our P/D converter the first 2 fuse slots are intended for low voltage use? I didn't use the 1st 2 fuse slots and wiring/fuses all is shifted over.
Our camper projects page
