RV.Net Open Roads Forum: Travel Trailers: Dometic RV Toilet - Model 300
 > Dometic RV Toilet - Model 300
Terry&Patrick
Ojai, CA
Posted: 12/23/20 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I recently bought a 2017 Keystone Bullet Premier and have just replaced the flush ball seal for the Dometic, model 300 toilet. Despite the new seal, water still seeps away from the bowl. Is there an adjustment for controlling the “pressure wipe” of the ball against the rubber seal?
Any thoughts on this would be greatly appreciated.
Patrick Russell
2017 Keystone Bullet Premier 19FBPR towed by a 2018 Jeep Grand Cherokee. Terry and I now have two small dogs - Sofie (Shih Tzu) and Cody (Silky Terrier Mix)
QCMan
Independent Republic of Horry
Posted: 12/23/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Is the valve tight? Is it worn?
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Old-Biscuit
Verde Valley
Posted: 12/23/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Check out this video----simple fix
IF that is NOT your issue then Reset the Bowl Seal
1. Hold flush ball open by pressing on pedal.
2. Using finger, apply moderate downward pressure around edge of ball seal.
3. Close flush ball.
4. Keeping flush ball closed, pour one quart of hot tap water into toilet bowl.
5. Let water cool completely.
6. Check for leak.
*Ball valve needs to be clean/No gouges/scrapes and move freely
Other then the pivot points there are NO adjustments
US NAVY------USS Decatur DDG31
cavie
Posted: 12/24/20 03:30am Link  |  Quote  |  Print  |  Notify Moderator
I understand that all 300 were recalled and replaced with 310's. Call the manufacturer.
Guy Roan
Posted: 12/24/20 04:02am Link  |  Quote  |  Print  |  Notify Moderator
On ours when it did that, I called Dometic and asked if their was any adjustment and if not could I buy a new one and the lady said no, but we will overnight us a whole new toilet and just discard that one.
Now two years later a few weeks ago, water leaked around the flush peddle unit on the new one
Since I have my trailer on a permanent site, I removed it and the black tank and installed a residential toilet along with a shut off in the water line and regular pvc piping.
Dometic stands by their toilets, but unfortunately their toilets are junk!
Guy
Lynnmor
Red Lion
Posted: 12/24/20 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I don't know what toilet the OP has, Dometic has 300 series toilets with model numbers of 310 and higher. The black seal and the flush valve are replaceable in this series, any other problems require a complete toilet replacement.
Old-Biscuit
Verde Valley
Posted: 12/24/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Dometic has:
300
301
310
311
320
321
Plus 500 series, 5000 series, 8500 series, 8700 series, etc, etc
OP stated they had a 300.....info concerning the bowl seal was posted
Dometic 300 Series were recalled due to leak between factory sealed bowl/base assembly.
To confirm if your toilet is part of the Dometic recall, check the toilet model and serial number on the label that is located on the toilet base under the water value. Have this information available when you call their Service Center at 800-321-9886 from 8 a.m. to 5 p.m. (ET).
** Usually can upgrade to 310 Porcelain Bowl----just pay upgrade fee
* This post was edited 12/24/20 09:10am by Old-Biscuit *
larry barnhart
wenatchee. wa usa
Posted: 12/24/20 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
This model can have this issue if you hold it open and brush inside to clean. this can move the pivot on the left side and the ball will not seal and leak. easy to fix and a u tube video showed me how and that fixed the issue. Had it for 5 winters and really like it because so easy to install a new seal.
chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Terry&Patrick
Ojai, CA
Posted: 01/16/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to thank those who suggested I contact Dometic about the issues on my model 300 toilet. I called customer service, quoted my serial # and the lady confirmed it was on the service bulletin. I chose to pay $100 to get a model 310 with self-closing, wooden seat. Otherwise, it was $75 for the standard toilet. Thank you Dometic. You were wonderful. It arrived 1-week later by UPS. Such an easy install!
MFL
Midwest
Posted: 01/16/21 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Nice of you to post, concerning your good experience with Dometic! It is good to know that some manufacturers will stand behind their product.
Jerry
