RV.Net Open Roads Forum: Reg cab long bed vs extended cab long bed?
 > Reg cab long bed vs extended cab long bed?
kohldad
Goose Creek, SC
Posted: 12/24/20 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
It's been a long time, but we carried an '70 Franklin 11' TC on our 69 Dodge reg cab power wagon. The truck was wrecked and we replaced the frame/body with a 76 Dodge Club cab truck. All the suspension, axles, and driveline were moved from the 69 to the 76. So the only difference was the wheelbase and a couple hundred pounds of the truck. The first time we carried the TC on a trip, my father was surprised at how much better the longer wheel base carried the camper. There was a lot less porposing when going down the road and over railroad tracks. The '69 wasn't bad in the least bit, but the extra 18" in wheel base was a very noticeable difference.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
specta
utah
Posted: 12/24/20 11:17pm Link  |  Quote  |  Print  |  Notify Moderator
Works great for me.
Regular cabs with 8' beds are soo much more maneuverable in parking lots and making u-turns.
If I bought a new truck today it would be just what I have.
And I have zero interest in a dually.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
Kayteg1
California > Nevada
Posted: 12/25/20 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I know Spectra that you drive mostly in the parks, but making a line on the picture, from where driver head is and under the front cabover- it makes about 30 degrees.
Meaning when you are at street light hanging 15' high, you need to back up about 50' to see it. That is safety concern.
JRscooby
Indepmo
Posted: 12/25/20 08:53am Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
Yes, a shorter wheelbase truck will carry a TC as well as a longer wheelbase truck. It will have the affect of moving weight closer to the front wheels. How much weight that actually makes it to the front wheels depends on the TC.
Anybody that has spent any time in the trucking industry will tell you that a longer wheelbase will let you have a higher GVW, without overloading the rear axles.
Back in the '50s you could buy a plastic prism to mount on the dash if you had a low sun-visor. Had one on the dash of my '67 Pete. If you got so it was past the visor edge light line you could tell the color.
Kayteg1
California > Nevada
Posted: 12/25/20 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Those were the years when we did not use seat belts neither?
specta
utah
Posted: 12/25/20 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Its not a safety concern at all. I drive all over and actually seldom in parks.
I don't know why everyone always thinks I can't see a street light unless I stop way back, its just not so.
Been down this path here before and its a non issue.
jimh406
Western MT
We aren’t talking about big rigs. We are also not talking about GVW or a rig with a trailer.
* This post was edited 12/25/20 09:53am by an administrator/moderator *
Posted: 12/25/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Everyone doesn’t, it’s just Kaytegs Christmas cheer! That we are blessed with year ‘round!
2017 Heartland Torque T29
JRscooby
Indepmo
Posted: 12/25/20 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Don't think the seat belts have much to do with seeing the traffic light. Of course, decades, and millions off miles, low visor never was issue. Little cars hiding under that long nose...
I'm not well educated, can you explain how the geometry is different big truck/little truck? And Gross Vehicle Weight ratio to front axle weight was part of your statement, and trailer was not part of mine.
jimh406
Western MT
Posted: 12/25/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Big trucks normally have at least 3 axles.
GVW is the Gross Vehicle Weight. In other words, the weight of the truck. If you mean to say longer trucks are heavier, I agree with that. Is that what you meant?
