RV.Net Open Roads Forum: Class A Motorhomes: Monaco
farmingdad
ky
Posted: 12/24/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Got a friend got 2008 signature and won’t start. Lights will come on and speedometer goes back forward and tach. Until you turn switch off. But I can go underneath the coach and start on starter. Need help.
Oasisbob
Portland Oregon 97266
Posted: 12/24/20 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
starter solenoid?
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
oldave
Tx
Posted: 12/24/20 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
My Monaco has a remote start switch in the engine compartment.
When looking around back there people often inadvertently flip
that switch without realizing it.
Mine is about head high on the left side. If I put my left hand up
to support myself that's about where my hand would be
corgidad
Posted: 12/24/20 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.monacoers.org/
Try posting on this site, a wealth of knowledge on all things Monaco. You will have to join and be approved but that does not take long.
tropical36
Southwest Florida_USA
Posted: 12/25/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
The most likely culprit is the aux solenoid which you'll find near the Starter by following the small pos wire back.
This is a chassis thing and a common failure on a Spartan. The good news is that Spartan usually has a better price than anyone for a replacement.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
farmingdad
ky
Posted: 12/25/20 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
It has road master chassis
Executive
Posted: 12/25/20 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Start with the batteries. Put a meter on them and see whether they're charged (at least 13VDC) Then check if he's been inside the rear run bay. There's two switches inside for a tech to start the coach without going all the way to the front cabin. Make sure it's switched for front and not rear. If it still won't start, turn the key to the ON position and try one of the switches in the rear run bay and see if it'll start......Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
tropical36
Posted: 12/25/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
It's still going to have an aux. solenoid near the main starter solenoid.
Batteries are obviously good if you can start it with the main solenoid.
I put bypass buttons in the engine compartment for both solenoids, when we got the coach. Not only can I always start it, if the starter is good, but they also troubleshoot to a certain extent.
Beats crawling down under in a rain storm and for possibly throwing sparks everywhere.
Ivylog
Blairsville, GA and WPB, FL.
Posted: 12/28/20 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
On the rear start board ^^^^ there are 2 fuses. One is for the starter and others for the fuel...check them. You can eliminate the front key start by turning the key on and going to the back and try starting from there.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
farmingdad
ky
Posted: 01/06/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Were is 2 selioniod on starter
