joelc
Cedar Point, NC
We have a Carriage Cameo and I am sure the shower is either a plastic or acrylic like any other RV. It is light brown in color and has many what appear to be water or lime spots which we can't get out. We have tried vinegar, dawn, murphy's soap, baking soda to no avail. I don't know if the white is wear or the color is only topical and worn. Is there a non invasive way to clean the shower and glass to get this film off? I am hesitant to use a fiberglass product that you would use on a Corvette as it might make the shower slippery.
larry barnhart
wenatchee. wa usa
Buy a blue can of easy off oven cleaner. I have had wonderful easy to do results. No fume is on the can. You could stray a small area and wait for maybe 30 minutes and wipe it off. When I do the whole shower as I have done 4 times 2 at home and 2 in fifth wheel I get in the shower and with a big plastic glass I throw water on walls and a rag to wipe off. No effort to do this .
chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Nv Guy
Reno NV
Try some Gel Gloss, I have used it to clean black streaks off aluminum coaches, we now use it to keep our shower water spot free. You can find it at Ace Hardware or other home improvement places.
Dick_B
Palos Heights, IL USA
What about CLR on a rag? An internet search has some ideas including Oxyclean.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Cummins12V98
on the road
larry barnhart wrote: Buy a blue can of easy off oven cleaner. I have had wonderful easy to do results. No fume is on the can. You could stray a small area and wait for maybe 30 minutes and wipe it off. When I do the whole shower as I have done 4 times 2 at home and 2 in fifth wheel I get in the shower and with a big plastic glass I throw water on walls and a rag to wipe off. No effort to do this .
chevman
Listen to Larry!!! I did and it works GREAT!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
theoldwizard1
SE MI
If the spot are not real bad, dampen a clean cloth with vinegar and wipe down the walls. You could also use orange/lemon/lime/grapefruit juice (citrus acid, strained).
obgraham
TriCites WA
I've had good success with CLR (diluted in water) and a gentle scrubby.
But I'm intrigued by the EaZOff idea -- might be less work!
joelc
Cedar Point, NC
Some good suggestions. Keep them coming. The stains look like lime deposits.
Cummins12V98
on the road
obgraham wrote: I've had good success with CLR (diluted in water) and a gentle scrubby.
Try it you will like it!!!
Edd505
Elephant Butte, NM
Cummins12V98 wrote: larry barnhart wrote: Buy a blue can of easy off oven cleaner. I have had wonderful easy to do results. No fume is on the can. You could stray a small area and wait for maybe 30 minutes and wipe it off. When I do the whole shower as I have done 4 times 2 at home and 2 in fifth wheel I get in the shower and with a big plastic glass I throw water on walls and a rag to wipe off. No effort to do this .
chevman
What does it do the colored aluminum on the shower doors?
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
