RV.Net Open Roads Forum: Fifth-Wheels: Cleaning shower with grey/white "water spots".
 > Cleaning shower with grey/white "water spots".
TxGearhead
Posted: 12/27/20 06:18am Link  |  Quote  |  Print  |  Notify Moderator
We use Wet & Forget for Showers on the home tile shower. Not sure it would immediately fix your problem though. But after you get it clean you may try the Wet & Forget to help keep it clean.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Cummins12V98
on the road
Posted: 12/27/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Edd505 wrote:
Cummins12V98 wrote:
larry barnhart wrote:
Buy a blue can of easy off oven cleaner. I have had wonderful easy to do results. No fume is on the can. You could stray a small area and wait for maybe 30 minutes and wipe it off. When I do the whole shower as I have done 4 times 2 at home and 2 in fifth wheel I get in the shower and with a big plastic glass I throw water on walls and a rag to wipe off. No effort to do this .
chevman
Listen to Larry!!! I did and it works GREAT!!!
What does it do the colored aluminum on the shower doors?
My aluminum is black and it makes it look new again.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
joelc
Cedar Point, NC
Posted: 12/29/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
We tried Wet and Forget. Does not work. Did not improve even a little. There is a note on the back of the bottle that it won't remove water spots. I want to try the oven cleaner next, but wife won't.
garyp4951
TN
Posted: 12/29/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
BarKeepers Friend, and windex works great for mineral deposits on auto glass, but not sure on fiberglass.
Edd505
Elephant Butte, NM
Posted: 12/29/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Cummins12V98 mines bronze colored, I'll try some inside in a corner. I tried something in my old Jayco that took the color off might have been CLR.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Bayley
Meridian
Posted: 12/29/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Once you get it clean.....I found the best way to keep the water spots away is to thoroughly wipe down and dry the shower and glass after use. I found this to be the best solution for the tile shower at home as well. No mold and mildew either.
Semper Fi
Tony, Darlene & the boss Bentley!
2013 Ram CTD, Ride-Rite Air Bags, B&W Turnover Ball and Andersen "Ultimate 5th Wheel Connection".
2014 Arctic Fox 29-5K 5th wheel with Reese Airborne Pin Box.
ford truck guy
Pennsylvania
Posted: 12/29/20 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
I just put a coat of wax on mine.... everything runs off with no water spots. just don't do the floor !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
larry barnhart
wenatchee. wa usa
Posted: 12/30/20 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
the blue can of easy off says not for aluminum. I didn't get any on our gold color Aluminum. Remember the blue can only. chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
on the road
Posted: 12/31/20 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I am betting plain ol aluminum is the issue. Using it on Anodized for me has been fine.
larry barnhart
wenatchee. wa usa
Posted: 12/31/20 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
To say more about what I did first was in the home and then the fifth but I decided to past wax the walls. I was a concrete finisher for half my working life and know hard work and rubbing that past wax off was about the hardest I had to rub off and then many years later I did the easy off and the wax turned yellow and had to redo many spots but finally I did and as I type I realize that was last summer. The wax was not needed but made the removal more work. a 2001 alpenlite fifthwheel that had a shower looking new when it was sold in July. The shower was of high quality. chevman
