RV.Net Open Roads Forum: Travel Trailers: Cold weather, water, what to do..
 > Cold weather, water, what to do..
falconbrother
North Carolina
Posted: 12/25/20 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
We're out camping at a KOA. It's supposed to be 25-26 degrees in the morning. The campground sent out a text saying disconnect the hose and leave their water bib dripping or, let the water drip in the RV. My plan is to disconnect the hose and let their faucet drip and use the on-board tank for water till things warm back up. My question is, if I let my faucet drip will it not fill up the grey tank and then over-fill it? I'd prefer to leave the hose connected and let my faucet drip. But, having a crisis in the wee hours does not appeal to me whatsoever.
Old-Biscuit
Verde Valley
Posted: 12/25/20 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
First off there is NO overflow on waste tanks ....it's WASTE and should be dumped according to local laws/restrictions
Grey could backup into shower
(Black could backup into toilet piping or even Vent line)
Only 'overflow' could happen if tanks were overfilled and they leaked into your underbelly
I ONLY use the fresh water tank/pump
Both are enclosed/heated etc ....I never leave a faucet dripping
IF CG wants there supply bibb dripping that's on them --- so just disconnect your hose, Drain it, Stow it and crack their bibb just enough to drip
US NAVY------USS Decatur DDG31
LibertyMan
Alabama
Posted: 12/25/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
I do not know why your gray tank would overfill if you leave the valve to the tank open, assuming you have full hook-ups. If you do not have sewer, simply fill fresh water tank and use it until the temps rise above freezing. Don't forget to put your water hose in your storage so it does not freeze as well.
2019 Rockwood Signature Ultra Lite
2016 Ram CCSB 2500 CTD
GenY Weight Distribution Hitch
Second Chance
Wherever...
Posted: 12/25/20 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Leaving the gray tank valve open and a faucet dripping inside would cause an ice dam in your stinky slinky - don't do it. Disconnecting the hose and letting their faucet drip while running off your fresh tank is the proper approach.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
time2roll
Posted: 12/25/20 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I would not leave anything dripping.
675w Solar pictures back up
azdryheat
Tucson, AZ
Posted: 12/25/20 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
We've done this many times. I disconnect the hose and blow the water out of it. Then I switch over to onboard water until the park's faucet supplies water again. I have about 160 gallons so water isn't an issue. We have electric heaters for the trailer but I still use the propane heater to keep the tanks and water lines from freezing.
FYI there are heated water lines on the market that make all of the above moot.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Posted: 12/25/20 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
Think about it logically.
Put some water in your tank if you want water without hooking up in the morning. Disconnect the water hose. Leave it off. If it’s not a frost free spigot, not your problem. Makes no sense to leave the hydrant dripping.
Leave your gray valve closed. Presuming it’s hooked up.
Don’t worry unless it’s not getting above freezing tomorrow.
Merry Christmas.
mobeewan
Hampton, Va
Posted: 12/26/20 02:11am Link  |  Quote  |  Print  |  Notify Moderator
I lived in my 3 season trailer here in southeast Va for 5 years. All you have to do is disconnect the fresh water hose when temps will be below freezing and use the onboard fresh water tank and pump. Leave the campground faucet dripping since they told you to, but be careful not to bust your butox on the ice when reconnecting the water hose.
If you do stay connected, open your grey water valve and leave the stinky slinky connected. The small trickle isn't going to freeze solid in the hose before warmer temps in the morning.
Guy Roan
Posted: 12/26/20 04:35am Link  |  Quote  |  Print  |  Notify Moderator
X's 2
Guy
falconbrother
North Carolina
Posted: 12/26/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
I just disconnected the hose and let their bibb drip. We used the pressure demand pump and no problems at all. By 10am things were thawing out. What I usually do is just not pay attention to the weather forecast and wake up at 4am to no water.
