RV.Net Open Roads Forum: Travel Trailers: Cold weather, water, what to do..
 > Cold weather, water, what to do..
Lantley
Ellicott City, Maryland
Posted: 12/26/20 09:27am Link  |  Quote  |  Print  |  Notify Moderator
This thread is full of erroneous advice. Lots of it from people in warm weather climates that really don't understand the scenario. Or have not regularly experienced cold weather.
If the CG wants you to let their faucets drip. Then let them drip otherwise their hose bibs may freeze and break, which will eventually cause campers grief.
Disconnect from the CG hose bib and use water from the RV fresh tank. Be sure to store RV hose inside where it won't freeze vs. leaving it outside to freeze.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
valhalla360
No paticular place.
Posted: 12/26/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you are on a sewer site, drain the waste tanks and leave them open for the night. Unless you use a lot of water, no real concerns with an ice dam (I'm assuming a short term over night cold snap followed by above freezing daytime temps. For long term freezing weather, ice dams are a concern.)
A far as the freshwater side, just disconnect and work off the pump. Do use the furnace rather than a space heater, as most are set up to dump a little heat into the underbelly slowing or stopping freezing of the tanks.
As far as the spigot, do what they asked...if it fails, it's the campgrounds problem if you did what they recommended.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rr2254545
Central Minnesota
Posted: 12/26/20 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Hint disconnecting the hose and letting it lay on the ground will still freeze the hose I bring mine in an put it in the shower
2012 Winnebago Journey 36M Cummins 360
2014 Jeep Cherokee, Air Force One, Blue Ox Avail tow bar
374 Campgrounds,85K miles driven in our Winnebago motor homes and 1858 nights camping since we retired in July 2009
2oldman
NM
Posted: 12/26/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I can imagine the icy watery mess the next day if everyone drips the CG spigots. I'd make sure you have plenty of water on board in case there's problems with the system. Also disconnect your sewer hose and drain it. In cold weather I'd be using my tank and pump exclusively.
Old-Biscuit
Verde Valley
Posted: 12/26/20 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I use my fresh water tank/pump exclusively Hot/Warm/Cold Temps
Fill tank...stow hose
Repeat as needed
Same with sewer hose
Connect ---dump...stow
Repeat as needed
NO Hoses laying about...connected or disconnected.
US NAVY------USS Decatur DDG31
2oldman
NM
Posted: 12/26/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
My strategy also. When I actually am in an RV park I dump, close everything and disconnect.
time2roll
Posted: 12/26/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I fully agree. Just saying if the campground has this recommendation what are we even talking about.
675w Solar pictures back up
Huntindog
Phoenix AZ
Posted: 12/26/20 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Disconnect the water hose. Leave it off. If it’s not a frost free spigot, not your problem. Makes no sense to leave the hydrant dripping.
It could be his problem.
If the spigot at his site is damaged due to his not following the CG directions... Then at the very least he may have to deal with the result for the rest of his stay.
Likely be a small flood, followed by no water at that site.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
540 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
