Boon Docker
agesilaus wrote: Old-Biscuit wrote: Wearing a Mask protects yourself AND OTHERS.
It's a SHAME others don't have the same respect and wear a Mask also
It really is that simple..........
Cloth masks do not work, period. They may stop some of the very largest particles when someone sneezes or coughs but does not stop the small particles. And when you cough you don't just produce extra large droplets, but rather the whole spectrum from extra tiny up. And for the vast majority of people with no symptoms all they do is restrict their breathing making respiratory problems worse.
Mayo Clinic did a study to show how effective masks are, they got some of those foam heads women use for wigs, stuck a tube out where the mouth would be, hooked the hose up to a BLOWER and pointed it at a mask wearing foam head six feet away. When the blowerized dummy was fitted with a mask and they blasted a continuous stream of plastic bead loaded air directly at the other dummy. That dummy's masks stopped one half of one percent of the beads. Over 90 percent remained floating around the blower head.
N95 masks issued to medics work somewhat if carefully worn and with the correct fitting, discarded frequently, and with no facial hair. HEPA mask do work when fitted correctly and without facial fair. Over the head forced air masks work very well but at the cost of several hundred bucks each and with changes of the expensive filters and batteries. I know since I was in charge of buying this stuff for an environmental lab.
Cloth masks are just tools to make the privileged class feel that they are forcing the proletariat, that's you, obey them.
That is not even close to being logical.
If that is true, how come places where mask are used have way less cases than places that don't use masks.
agesilaus
North Florida
Quote: If that is true, how come places where mask are used have way less cases than places that don't use masks.
OK, prove that point. Show us data.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Boon Docker
agesilaus wrote: Quote: If that is true, how come places where mask are used have way less cases than places that don't use masks.
Simple, just look at the published stats.
agesilaus
North Florida
Boon Docker wrote: agesilaus wrote: Quote: If that is true, how come places where mask are used have way less cases than places that don't use masks.
See all talk, or text I guess and no data. It is your proposition you provide the data.
Boon Docker
![doh [emoticon]](http://www.rv.net/sharedcontent/cfb/images/doh.gif)
I'm done, the stupidity around here is too much to bare.
Guy Roan
Wow !
When I posted I never realized there were so many stubborn people who could care less about anyone except their self !
You know who you are, and you have my sympathy !
Guy
bgum
South Louisiana
The naysayers will hurt you every time. First it was a hoax. Then it wasn't as bad as the seasonal flu. You don't need to wear mask. It only infects the old and infirmed. The doctors and scientists are all wrong. How many times can you be wrong and stick to a belief? Do what you want just don't get near me.
There is some question about the massaging of the numbers in Florida. It appears their numbers are questionable.
IAMICHABOD
Sunny So Cal 90713
A bit of a Long Read
But to cut to the chase
Conclusion
The study provides evidence that US states mandating the use of face masks in public had a greater decline in daily COVID-19 growth rates after issuing these mandates compared with states that did not issue mandates. These effects were observed conditional on other existing social distancing measures and were independent of the CDC recommendation to wear face covers issued April 3, 2020. As international and state governments begin to relax social distancing restrictions, and considering the high likelihood of a second COVID-19 wave in the fall and winter of 2020,30 requiring the use of face masks in public could help in reducing COVID-19 spread.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
spoon059
Just north of D.C.
Boon Docker wrote: Simple, just look at the published stats.
Look at the study that he posted. It showed that counties in Florida that implemented mask mandates averaged 23 cases a day. Counties that didn't averaged 22 cases a day. Then it went on to show other states that had mask mandates and the numbers, versus other states that had mask mandates. Masks aren't the panacea that people claim they are. N95 masks offer very good protection. Surgical masks offer decent protection. Regular cloth masks are minimally better then nothing at all. There were studies that showed gaiters are WORSE than no mask.
Then when you consider that people are touching the outside ("infected" side) of masks when they take them off and not washing hands immediately, those masks have a greater chance of spreading disease.
Washing hands, not touching your face and not getting into peoples personal space is FAR more effective and less restrictive. I feel like an idiot standing outside wearing a mask at a gas station in the 21 degree temperatures and watching my breath, and the breath of everyone around me, going right through or around their masks and exposing their spittle to everyone else. These pieces of cloth and/or paper masks aren't stopping anything.
2015 Ram CTD
2015 Jayco 29QBS
NamMedevac 70
Reno
If mask do not work then why have doctors and nurses wore them for many many decades around infected people with flu, pneumonia, TB, and many other infectious diseases before covid and most of them did not die. They been doing this for over a century.
This year mask work for me as unlike previous 3 to 5 years I have not been sick with flu or cold by this time. I am a believer and wear them when around other folks indoors or outside. Before flying Army medevac choopers in Nam I was an emergency ambulance driver in Texas and we wore them around suspected infected persons and never did get sick.
C heers
edited 12/26/20 05:12pm by NamMedevac 70 *
