RV.Net Open Roads Forum: Tech Issues: GFIC tripping
 > GFIC tripping
vermilye
Oswego, NY, USA
Posted: 12/27/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
simply plug into a non-gfi circuit. You are not plugged into a gfi circuit when on shore power in a campground.
Evidently you have not camped in Trail of Tears State Park, MO. ALL receptacles, 15, 30, and 50 amp are GFCIs. I've stayed in one other Missouri state park that also had GFCIs on all the receptacles - maybe it is all of the state parks...
It is worth taking the time to find what is causing the trip & fixing it. Bobbo's description of finding the fault is a good one, although I'd start with checking the adapters first.
Jon Vermilye My Travel Blog
My Photo & RV link blog
ppine
Northern Nevada
Posted: 12/27/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
GFIs are very sensitive. They trip all the time.
Many MHs and TTs have a 30 amp system but are plugged into a barn or garage with a 20 amp circuit.
Sometimes your rig with a GFI is plugged into a garage circuit with GFI. They fight each other and trip.
joshuajim
Mojave Desert
Posted: 12/27/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
It would be very unsafe to eliminate this GFCI as it’s on the outside of the barn and is used for other power tools. Don’t think I like the possibility of being electrocuted.
RVing since 1995.
enblethen
Moses Lake, WA
Posted: 12/27/20 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
You need to fix the problem. The idea to use a non-GFCI receptacle to mask the problem would be a mistake.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Edd505
Elephant Butte, NM
Posted: 12/27/20 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Is the outside outlet wet? Seems every time mine trips the outside outlets covers been open & gotten wet. They will trip when over loaded (wifes hair dryer) and they get weak after being tripped a couple times.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
ktmrfs
Portland, Oregon
Posted: 12/28/20 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
uh.... how many times has your hair dryer, electric pressure washer etcl with GFI tripped and faught with the breaker panel GFI????
IMHO pure BS. Downstream GFI's work well with an breaker panel or upstream GFI.
I've got literally dozens of downstream GFI devices used in the house and trailer along with breaker panel GFCI/AFCI on all my circuits and NEVER have had an issue with a downstream GFCI causing conflict or tripping with a breaker panel GFI or vice versa.
Same with our son in his house.
any time one or the other tripped it was a FAULT, pure and simple. They did what they were supposed to do.
2011 Keystone Outback 295RE
Bobbo
Wherever I park
Posted: 12/28/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
True. GFCI's fighting each other and tripping is a myth. But it is a commonly believed myth.
Bobbo and Lin
 > GFIC tripping
