RV.Net Open Roads Forum: How do you transport your mobioity scooter
 > How do you transport your mobioity scooter
bigred1cav
ohio
Posted: 12/27/20 10:21am Link  |  Quote  |  Print  |  Notify Moderator
I have a mobility scooter that does not break down to small parts. I tow a car so on the back is not an option the toad is too small to put a carrier on the back.
Posted: 12/27/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Front rack with a cover on it is the only option then. It appears anyway.
2017 Heartland Torque T29
Dutch_12078
Winters south, summers north
Posted: 12/27/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
When my wife's sister traveled with us for a few years, we carried her non-break down scooter in the back of our then 2002 RAV4 toad. I installed an electric lift that made loading and unloading quite easy. We had to fold down one of the rear seats to make room for the scooter.
Dutch
2001 GBM Landau 34' Class A
Anza-Borrego Desert SP area
Posted: 12/27/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Is your front axle weight under max enough to consider a front end rack etc.?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
dpgllg
South West Pennsylvania
Posted: 12/27/20 10:35am Link  |  Quote  |  Print  |  Notify Moderator
I'm fortunate that mine breaks down and fits into front compartment of 5th wheel. I then put it into back of truck to haul when out and about. I have a fold up cover on truck so it is protected.
I am assuming that you have a motor home with toad. One possible option would be a reciever installed on front of motorhome but then how would you transport when out in the toad?
Maybe provide a description of motorhome and toad and someone might have already solved this issue.
Dave
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus two Cocker Spaniels and a Standard Poodle
CA Traveler
The Western States
Posted: 12/27/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I use a pair of 12"x90" foldable ramps. With the scooter they fill the back of the car. Make sure you have headroom and depth for the scooter and the ramps. You should have holddown for straps to secure everything.
I also have a non motorized carrier on the back of the car for the scooter but the scooter is inside the car when towed to eliminate dirt and water. Scooter plus carrier weighs about 240 lbs.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 12/27/20 11:35am Link  |  Quote  |  Print  |  Notify Moderator
Our scooter has very low clearance and this includes the 2 small wheels behind the rear wheels that prevent the scooter from tipping up like on a grade. Check your scooter clearance for the ramps.
Posted: 12/27/20 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Why do some of you just tell stories that aren’t applicable or helpful to the OPs question?
CA Traveler
The Western States
Posted: 12/27/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I use these ramps.
https://www.amazon.com/Aluminum-Lawnmowe........d=1&keywords=ramps&qid=1609113068&sr=8-3
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 12/28/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I understand you have a scooter already but often a used one that breaks down is very inexpensive. I have purchased three of them and they were quite new. Both for $500 or less. They have smaller tires so are not good in gravel etc but are perfect for theme park usage or the like.
I carried two of them in the back of my Ford Edge.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
