Rock_in
Indiana
Had a phone conversation with Forest River Rep for a brand they make. The pinboxes are indeed not changeable or adjustable verically. they can be replaced by dealer but only with Turning Point OEM replacement. Lippert calculated an average height measurement for pin box plate. On one brand with camper level-49.5"(my tape measure from ground). With 17 inch hitch (b&w low setting), my STOCK dodge is 53". letting my truck down to level camper means truck not level. Makers have written off a small RVer segment who want short and light fifth wheels. Unless of course you pull a 9000lb with a 1/2 ton truck. Indeed possible, as that is what these new short 5th wheels are made for with non adjustable hitch, but 1. not buying new truck and 2. pull that thru mountains with 1/2 ton. B&W, Curt and others do allow wedge on specific hitches. Not single point hitch due to stresses though.
GDS-3950BH
DC
Rock_in wrote: Makers have written off a small RVer segment who want short and light fifth wheels.
They did not write anybody off, they went with the cheapest option possible where they could throw the most $ at the bottom line like they do with everything, and it usually involves Lippert. Most have the same MO and if you think they don't your living in Fantasy land. Bottom line is they could care less if you purchase as they know someone else will.
dryfly
garyp4951 wrote: I would not purchase a 5th wheel with that pinbox, due to the wedge insert prying on your hitch head at every turn, and you can only hitch up if your straight in line with the rv.
There are many other choices for short bed trucks beside this one.
I guess it goes without saying, but you do not have to use the wedge and the Turning Point feature. I have mine locked down, and not using the wedge and it functions as a regular pin box.
I agree a big limitation is the lack of vertical adjustment. However most 5th wheel hitches allow for some.
I've had a slider hitch on two trailers over the past 12 years. I've never once had the need to use it. I trust most folks know how much stress it puts on the trailer's suspension and the tires when one turns a trailer 90 degrees. I barely trust my spring hangers going straight down the road now.
time2roll
If the trailer includes a feature you don't like.... move on to a different model or manufacturer.
For many just having a lippert frame would be a no go.
675w Solar pictures back up
Shal36
Winter Springs, FL
Don’t do it. It will really limit your options to resolve issues with your current truck or the next truck you buy.
Curly2001
Tucson, Arizona
It's hard enough to match a truck, hitch, and trailer without being stuck with a non-adjustable hitch. I am nose high with mine now due to the truck height and am not a happy camper even though I have a fully adjustable hitch.
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
johndeerefarmer
My GD Reflection 150 series has one of those. Only one set of adjustment holes- I think and no other pin box will fit in it's place. Stupid design...
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflections 220rk & 29rs
