RV.Net Open Roads Forum: Truck Campers: lance max/ af 1150 question
 > lance max/ af 1150 question
Ernie Fergler
Iowa
Posted: 12/27/20 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
For those familiar with the lance 981 or af 1150, Im wondering if either of these are usable with the slide in. By usable, I mean accessable for quick lunch / bathroom breaks. Ive only seen these campers through photos with the slide extended, and cant determine what they look like closed up. I called both dealers and asked. First dealer responded "no idea". Second one responded "I spose you could". Not too many TC knowlegable dealers in the midwest. Both of these campers are 2005 models and are 280 miles from me, seperate dealerships, 40 miles apart. Difficult to look at both in 1 day, 1 trip. Would like to hear comments on both of these campers from former/ current owners. Ive owned a class c, and 2 5th wheels, but the only things I know about TC's, is what Ive learned from the guys on this forum. So thank you all for what I think I know.
2016 Ram 3500 dually, Aisen, 4.10 gear, 4x4, 8 ft bed
2020 Grand Design Reflection 337RLS
"Just because you can, doesn't mean you should."
Posted: 12/27/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
AF is totally useable with slide in. Sticks into doorway about 6” when fully closed.
Slider switch is right by bottom of entry door so also super easy to run it out a little or a lot depending on what you want, provided you keep everything out of the way of the slide out.
2017 Heartland Torque T29
Bert the Welder
Van. Island
Posted: 12/27/20 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
No idea. Also something I've wondered.
But at least by their answer they've show ignorance and/or incompetence. So you know to tread cautiously when buying from them or avoiding them all together.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
Posted: 12/27/20 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
As far as other comments you asked for, both are 15 years old and at a dealer who will have about a zero % chance of knowing their history or even caring about that.
You however should have a keen interest in the campers’ history, particularly how it was cared for and how it was stored.
Proceed with great caution with a totally unknown old camper in the middle of winter.
There is a good chance that both of them leak or have leaked.
kohldad
Goose Creek, SC
Posted: 12/27/20 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
From memory of other post, believe you have to put the slides out at least 6" to be able to use any of the facilities. By pulling images into paint and making the slide go in, looks like the minimum of 6" is accurate but think they need to both go about 1/2 way out for anything but a skinny person or contortionist to use. Hopefully other actual owners will post up.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Posted: 12/27/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
^ Or if you read my post, AFs are useable. I guess if you’re really fat they’re not....
Bert, you hit the nail on the head. Reading comprehension is poor at best here.
FireGuard
Frazier Park
Posted: 12/27/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 981 and you can squeeze past the dinette with the slide in and use everything.
A little tight but doable.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
notsobigjoe
southeast
Posted: 12/28/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
2007 Lance 1181 here and it's a squeeze. but can be done. As said above I push it out 6 inches. Good luck with your quest!
mellow
Salisbury, MD
Posted: 12/28/20 09:45am Link  |  Quote  |  Print  |  Notify Moderator
If your looking for one useable with the slide in check out the 1191, plenty of space with the slide in, even more with it out.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
Ernie Fergler
Iowa
Posted: 12/28/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Thx to all that replied, with special thanks to Grit Dog, because his answer was the one I wanted to see, even though the AF is my 2nd choice of the 2.
I've been shopping for a TC for over 10 years looking for the "right" one. It will be my secondary camper used for a trip to Alaska ,and short stays at nat. parks and blm camping. I have a 5th wheel for longer, less mobile stays. My budget is under 15K, hence the age of these 2, both listed at 10ish. When I first started looking, my budget was 10K and you could get a '99 or '00 model for that price. Today, the same 10K will buy about the same camper. In today's covid market hard side campers in my price range just don't exist.
Thx again for the replies.
Ernie
