RV.Net Open Roads Forum: A top to bottom look at green energy
Search only in Tow Vehicles
 > A top to bottom look at green energy
Page of 6
valhalla360
No paticular place.
Posted: 12/28/20 04:17pm Link  |  Print  |  Notify Moderator
time2roll wrote:
valhalla360 wrote:
So where exactly will the asphalt for the roads come from? Right now probably 70-80% of lane miles are asphalt (and portland cement concrete isn't exactly a green product).
Nothing political about it. What will these big beautiful roads be built from?
Does making asphalt roads include burning the tar or can it just be mixed with the aggregate and rolled out?
You generally have to heat it up to around 400F, mix and then roll out. Cold patch used to be mixed with gasoline to keep it from setting. When the gasoline evaporated, it would effectively set but that's a big no-no due to the emissions now.
The problem with recycling asphalt is as it ages, the lighter components evaporate away and it becomes brittle, so while you can recycle it to a small degree the recycled asphalt still needs fresh asphalt added and it doesn't hold up as well as virgin asphalt pavement. Also, you can't control the agregate as you are stuck with whatever was in the original mix and that mix is broken up by the milling process. Usually, recycled asphalt is used for parking lots and light duty roads.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
valhalla360
No paticular place.
Posted: 12/28/20 04:21pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
valhalla360 wrote:
India is having good success with recycling plastic for roads.
First, the plastic is not the binder but an aggregate replacement (it replaces some of the sand and gravel). (They do similar with ground up tires)
Second, plastic is made from....crude oil. While there is a small amount made from plant sources, it generally doesn't have good long term durability. In fact it's promoted based on the fact that it breaks down fairly quickly...not so great for a road where you are shooting for a 20-30yr lifespan.
This article is from 2016 so the road is now 18 years old. "Jambulingam Street, Chennai, is a local legend. The tar road in the bustling Nungambakkam area has weathered a major flood, several monsoons, recurring heat waves and a steady stream of cars, trucks and auto rickshaws without showing the usual signs of wear and tear. Built in 2002, it has not developed the mosaic of cracks, potholes or craters that typically make their appearance after it rains. Holding the road together is an unremarkable material: a cheap, polymer glue made from shredded waste plastic."
https://www.theguardian.com/sustainable-........ic-transport-environment-pollution-waste
From the picture that is a small local road with negligible truck traffic.
Geo*Boy
Unknown
Posted: 12/28/20 05:23pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
How much nuclear fuel is there?
"As of 2017, identified uranium reserves recoverable at US$130/kg were 6.14 million tons (compared to 5.72 million tons in 2015). At the rate of consumption in 2017, these reserves are sufficient for slightly over 130 years of supply. The identified reserves as of 2017 recoverable at US$260/kg are 7.99 million tons (compared to 7.64 million tons in 2015)."
The problem is that the current long term prices is $78/kg.
The elephant in the room is waste storage. Some suggest using breeder technology to reprocess the fuel. But, there are few breeder reactors--and it is cheaper to mine uranium for fuel than to use this technology. Russia and China have a couple each, with one in China being the most recent.
The point is that nuclear is NOT a renewable energy source.
No body wants to talk about the toxic waste that that ALL the current solar panels are going to be when they reach their end life. There is no money or plan to dispose of that waste safely.
pianotuna
Regina, SK, Canada
Posted: 12/28/20 05:34pm Link  |  Print  |  Notify Moderator
Define 'end of life'.
Define 'toxic'. Nuclear waste is toxic for many centuries.
And, it is possible to recycle panels . This article is from 2017.
https://www.greenmatch.co.uk/blog/2017/1........e-opportunities-of-solar-panel-recycling
* This post was edited 12/29/20 09:44am by pianotuna *
Regards, Don
GDS-3950BH
DC
Posted: 12/28/20 08:16pm Link  |  Print  |  Notify Moderator
free radical wrote:
I dont think we can go full green energy anytime soon,bc airplanes for example will need FF for long time yet
However for shorter cross country trip electric high speed trains would do better,especialy for people who dont like to fly
But then we would have to hire chinese or Japanese to build it as our leaders dont seem to know how.
China high speed railways
https://youtu.be/aXo7wi488Eo
Where do they get power to run,,hydroelectric,wind,solar,etc and now
China already leads in renewable energy
https://youtu.be/Lvem_WvLiDU
How can they acomplish so much in such short time
China is run by engineers and well educated scientists,financial experts,not by some washed out tv personality science denier.
https://youtu.be/A3SbhDZtFsk
China is investing in infrastructure,roads,bridges,housing creating jobs for everyone and not wastin money on military no doubt helps.
https://youtu.be/TbyBKTqnkdo
They're the greatest, just follow the rules though or end up being sent to work camp or possibly just dissappear altogether. Those silly Chinese. Perhaps you should move there.
Reisender
NA
Posted: 12/28/20 08:44pm Link  |  Print  |  Notify Moderator
Lots of high speed train manufacturers out there. Spanish, French, German, Japanese. Spend some time on high speed train transport and you might change your tune a bit.
free radical
Canada
Posted: 12/28/20 09:36pm Link  |  Print  |  Notify Moderator
Have you ever seen any Our News network post positive Truthful facts about China like I just did here?
They cant,why not?
and you wanna brag about Freedom o Speach,seriously.
Oh yes the work camps,
Did you know that Taliban from neigborin Afganistan atacked Tibet China and murdered thousands of civilians not long ago tryin to instal Sharia law?
Why dont western media report on that?
Yet
China still allows ALL religions including Islam and even has 35.000 Islamic Mosques.
https://youtu.be/soPJESgkE5k
Maybe we should have work camps too,so we wouldnt have so many homeless Lol
I talk w many western expats livin in china and they all love it
Plenty o work low cost livin and no homeles junkies,
Its simple China executes drug pushers and life is good
See Reforterfy media travel if you dont believe me
https://youtu.be/yIbmL17P3nc
Or try
Gweilo60 or Nathan Rich or Blondie in China or Mexicanos in china or
Richard Augilar chanel,good luck getin woke
Most americans big egos cant accept that some other system is better
Especialy if it has comunism name,but china uses capitalist system also as the largest number of Bilionaires in the world proves.
What democracy means to chinese
https://youtu.be/nl59t---30g
free radical
Canada
Posted: 12/28/20 10:02pm Link  |  Print  |  Notify Moderator
I dont dispute that,
so why cant we build such high speed railways here.?
Its obviously cleaner then burning fosil fuels.
Also
Japanese bullet trains have been trouble free over 40 years running,why are our slow trains so accident prone?
Could be that asians work ethics are better.
https://youtu.be/JWuT_yeQ0PY
GDS-3950BH
DC
Posted: 12/29/20 01:56am Link  |  Print  |  Notify Moderator
Also
Here is some help with your problem.
Huntindog
Phoenix AZ
Posted: 12/29/20 02:23am Link  |  Print  |  Notify Moderator
As far as trains go, I imagine the enviromental
study could be wrapped up in 10-20 years.
[emoticon]
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1380watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Page of 6
