trailernovice
Mission TX
Our trailer has the new type of roof television antenna...stays in place, as opposed to the older 'crank it up and down / turn it to point toward wherever signal is best' type
Even with that, sometimes beyond signal range for over-the-air broadcast channels
Came across a tripod-mounted flying-saucer shaped antenna described as: KING OmniGo Portable Omnidirectional Over-The-Air HDTV Antenna, Black...it would sit on the ground, and connect through the 'cable in' outlet on the outside of the trailer
Would this be any better at picking up signals that the factory roof-mounted antenna we already have does?
(not interested in a satellite solution...we're occasional weekenders, and our trailer isn't the type for long-term television watching)
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
Death Valley NP
Height is usually helpful. The King would be lower than what you have IMO. And you must set it up and take it down.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bgum
South Louisiana
Not any better sitting on tripod. Elevated may help
Dutch_12078
Winters south, summers north
The common Winegard Sensar crankup antennas are still the leader in RV OTA antennas. Nearly any directional antenna will beat an omni-directional antenna, but in nearly all cases height is might with antennas regardless of design.
Dutch
2001 GBM Landau 34' Class A
jorbill2or
Full time
Omni on any antenna means a lousy range in all directions but if your close it’s easy ... no pointing, which to some is “better” . You can get better distance reception with a directional like the winegard batwing with the uhf add on but you will have to get up and point the antenna .. sometimes at different places in the same location depending on where the transmitters are. You can get an app to figure out where that is . Secondly unobstructed height and size is king ! If your antenna is blocked by say , by the air conditioning... no joy.
edited 12/28/20 03:40pm by jorbill2or *
Bill
Wherever I happen to park
The not always a joke about Omni Directional Antennas is "They work equally bad in all directions"
For RV use I would recommend scrap the omni on the roof and put in a Winegard Sensar IV with the optional Sensar Pro Wall plate... This is one you crank up and point.
or you can get any number of fairly good pole mounted... Put 'em up 20 or 30 feet on top of a flag pole and again a directional antenna is your best choice.. that flag pole can be a touch costly though
But a high gain antenna at height can't be beat.
edited 12/29/20 04:23am by wa8yxm *
Home is where I park it.
Edd505
Elephant Butte, NM
Replace the omni with a King, it can be aimed.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
KD4UPL
Swoope, VA
A directional will beat an omni every time. Also, an antenna on the roof should beat one on the ground every time due to higher elevation.
theoldwizard1
SE MI
KD4UPL wrote: A directional will beat an omni every time. Also, an antenna on the roof should beat one on the ground every time due to higher elevation.
Both statements are accurate !
With OTA being 100% digital, it is harder to tell if you are pointing in the "optimal" direction.
Old-Biscuit
Verde Valley
Some times our Winegard Crank up would only pull in a couple of channels
So I went down to an ACE Hardware in the closest town and bought a Outdoor TV antenna for $40 or so (it has been a while...IIRC 2011)
Also bought a 5' section of pipe 1" DIA
*stowed it in basement compartment of 5vr. would just fit side to side
Attached the antenna to top of pipe ...connected a length of coax and mounted the pipe in the Flag Buddy Mounts I had on my Ladder
Pointed front of antenna towards the Tower as depicted on the 'antennaweb.org' site (gives direction/distance/channels available info)
Connected the coax to the 'cable' input on rear of 5vr
Changed BOMB to Cable (turned booster off cause not using the OEM antenna) and Auto Scanned for channels
Picked up roughly 12 channels...10 more then Crank up pulled in
I now use that same antenna on Two 10' pipes at my S&B
roughly 25 channels (that we watch) for Free
and roughly 10 others that we deleted
