RV.Net Open Roads Forum: Class A Motorhomes: Ford Triton V-10 Info Request
 > Ford Triton V-10 Info Request
Edd505
Elephant Butte, NM
Posted: 12/29/20 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Get the vin off anything your interested in and run it here, it will tell you exactley what your looking at. Vin Decoder
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
dodge guy
Bartlett IL
Posted: 12/29/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
cbr46 wrote:
Let's not forget the spark plug issues of the 2V & 3V. The 2V heads have limited threads - be sure to use a torque wrench and not "guttentight". I replaced mine at 130k miles when the engine started running a little rough. I also replaced the coil-over-plug boots. It still has a slight stumble at low load around 1500 rpm. Kinda weird, actually.
The 3V plugs like to carbon up and stick, breaking the porcelain from the metal with the plug dropping into the cylinder (the plug is a very strange design). There's a kit to remove the dropped plug but it's expensive (relative term). Still better than pulling the head off. A buddy mechanic likes to hit the 3V plugs with short bursts of an impact wrench.
Best,
- bob
As has been said the V-10 spitting the plugs was fixed in 03 (late 02 on my late build Excursion). so basically 02-current 2 valve V-10`s dont have the issue. the early 3 valve Tritons had the plug breaking problem. again that was fixed in 2010 with a new design plug.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
vjstangelo
virginia
Posted: 01/02/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I have owned both the 2 valve V10 with the 4r100 and the 3 valve with the 5r110. Hands down choose the 3 valve with the 5r110. It has much better gearing for the hills along with take off power.
2012 Winnebago Vista 32K
2011 Honda CRV Toad
