RV.Net Open Roads Forum: Tow Vehicles: SRW Tires
Search only in Tow Vehicles
 > SRW Tires
Dave H M
IL
Posted: 12/29/20 03:28am Link  |  Quote  |  Print  |  Notify Moderator
I tow with an F250 and am always concerned/watch the weight capacity of the tires. I see the folks referring to the weight ratings of the F350.
What kind of tires/weight ratings do the SRW 350's have that helps boost the hauling capacity.
Seems like only E Rated are available for my F250 with 17" rims. thanx
valhalla360
No paticular place.
Posted: 12/29/20 06:35am Link  |  Quote  |  Print  |  Notify Moderator
You may need to change tire size to get the higher ratings (don't forget to check the rim rating also).
Newer models are different but for a very long time when looking at SRW, the difference was the spring pack being stronger in the F350 but otherwise, they were essentially identical trucks.
So if you bump up the spring pack to match the F350 and make sure the rims and tires match, you for practical purposes have an F350.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
RobWNY
Jamestown, NY
Posted: 12/29/20 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Putting sticker numbers, Spring packs, Timbrens, Air bags and what's considered legal weight aside for a minute, aren't the two real determining factors what a truck can handle the GAWR and the Max tire weight rating with the tires truly being the weak link because the axels can really handle more than their rating? Maybe I'm missing something but if I had the same E rated tires with weight ratings of 3,750 pounds on a 3/4 ton and a one ton truck, regardless of what was added to beef things up, isn't the max payload of both trucks 7,500 pounds? Isn't the tire ratings usually the weak link in max weight capability in heavy duty trucks?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Dave H M
IL
Posted: 12/29/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
That is what I am talking about Rob.
I don't see how the 350"s can be advertised as big load carriers if the tires are the same E rating as 250's. [emoticon]
BurbMan
Islip, Long Island
Posted: 12/29/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Dave, you're on the right track, but the key is this:
valhalla360 wrote:
You may need to change tire size to get the higher ratings...
You are correct that the RAWR on SRW trucks is mostly the product of twice the rear tire rating. However, not all E rated tires are rated the same...
I happened to be looking at Nitto Ridge Grapplers so we can use that as an example. Look HERE at the load rating table for 17" tires. The highest load-rated tire is the LT285/75-17E at 3195 lbs.
Now look HERE at the ratings for 18" tires...that same tire in LT 285/75-18E is rated at 4080 lbs.
In this example going from 17" to 18" with the same 285/75-E tires nets up an increase of 1,770 in RAWR just from the tires.
Make sense?
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
JIMNLIN
Oklahoma
Posted: 12/29/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
With todays 18" and 20" LT E in the 3800-4000 lb range tires the weak link is OEM wheels and OEM rear spring pack ratings.
F250's come with 17" or 18" and 20" wheels so moving up to LT E in a 20" wheel gains a lot of capacity over 17" sizes.
MFL
Midwest
Posted: 12/29/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Dave...I don't think it is the E rating determining your capacity. You need to look at the tire load carrying numbers. In a 245/17 size, with narrow wheels, not a lot of options.
While you may find a few tires in 17", with a bit more capacity, than OEM, you would find many options by moving to 18" wheels/tires.
In my area, most dealers, when ordering for their sales lot, order with 18" similar tires and wheels on the 250s, as on the 350s.
One thing to consider with your 6.2 gas, is the larger, more capable, tires/wheels, will reduce the advantage of your 4.30 gears.
Jerry
Old-Biscuit
Verde Valley
Posted: 12/29/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Make sense?
THIS^^^^^^^^^^
My 3500 SRW came with 17" 'E' Rated tires......3195# each
RAWR is 6200#
17" tire ratings are LIMITED
StirCrazy
Kamloops, BC, Canada
Posted: 12/29/20 09:09am Link  |  Quote  |  Print  |  Notify Moderator
when I bought mine to get the 11500 gvw package you had to get the 20" wheel option otherwise you could only get a 11000 gvw truck. it came with 20" BFG all terain ta's from the factory, I now have 20" Sailun terramax on it for the last two sets of tires.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
valhalla360
No paticular place.
Posted: 12/29/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Personally, I stopped looking at Letter Grade Ratings. It's an outdated system based on when they made stronger tires by adding more plys to the tire.
Look for Load Ratings that meet your needs.
But it's also the springs in many cases that are also a limiting factor. The axle itself is usually the same. The GAWR is the weakest link in the rear suspension, not necessarily the axle itself.
 > SRW Tires
