RV.Net Open Roads Forum: Tow Vehicles: SRW Tires
Search only in Tow Vehicles
 > SRW Tires
BurbMan
Islip, Long Island
Posted: 12/29/20 10:27am Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
when I bought mine to get the 11500 gvw package you had to get the 20" wheel option otherwise you could only get a 11000 gvw truck.
I have 12,300 GVWR with 18" factory wheels.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
RoyF
Fayetteville Arkansas
Posted: 12/29/20 10:36am Link  |  Quote  |  Print  |  Notify Moderator
From the 2020 Ford-heavy-duty brochure, there is a ovelap in payloads for the F250 and F350. (These figures may be slightly different for 2021.)
There are many GVWR choices: 9,900 up to 10,800 for the F250; 10,000 up to 12,400 for the SRW F350. Adding 4-wheel drive to either reduces the payload by 400 to 500 lbs. And, for some reason, adding a high-capacity towing package to the F250 reduces its payload.
With so many variables (GVWR, regular or crew cab, short or long bed) there is considerable overlap between the highest F250 and the lowest SRW F350 payloads.
For the crew-cab short-bed preferred by many RVers, the numbers for the F250 with tow package are 3,750 (4x2) or 3,320 lbs. (4x4).
For a comparable SWR F350, the numbers vary from 3,650 (4x2) or 3,220 (4x4) up to 4,460 depending on the choice of GVWR.
For a crew-cab long bed, the numbers for the F250 with tow package are 3,520 (4x2) or 3,040 (4x4).
For a comparable SWR F350, the numbers vary from 2,990 (4x4 with lowest GVWR) up to 4,730.
Bottom line: the SWR F350 payload for a given configuration is generally (but not always) about 500 lbs. greater than that of the F250. The payload depends highly on the configuration: GVWR, choice of engine, cab, and bed.
For maximum payload, the F250 short-bed, regular cab and no tow-package can have payload up to 4,260 lbs. (4x2) or 3,820 (4x4).
The SRW F350 short-bed, regular cab can have payload from 3,630 up to 4,960 lbs, depending on the choice of GVWR.
To make a choice between F250 or SRW F350, it seems that one should first decide about the cab, the bed, 4x2 or 4x4, and the engine. Next, we need the required payload: hitch weight, weight of fuel, other things in the bed and back seat. Add a few hundred pounds for good measure. Only then can you make a choice.
ps: my 2008 SRW F350 is showing signs of age (not with engine or transmission, but with various other things), so I am trading for a 2021 SWR F350: a special order to get exactly what I want, and hoping for delivery in February. That's why I have been looking so carefully at these numbers.
Dave H M
IL
Posted: 12/29/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Dang, you folks provided all the skinny I was wondering about.
Duuuh, I failed to speck out the load rating/RAWR of the ole F250 CC short box when I ordered it. [emoticon]
Yeah and as stated, the 6.2 even with 4.30's does not spend the majority of its time in 6th when yanking the 10K fifth wheel from central IL to Myrtle Beach/Murrells Inlet SC. Don't get me wrong, I am happier in a pig in you know what with the F250 over all.
Thanks again
RobWNY
Jamestown, NY
Posted: 12/29/20 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again
Pigpen?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Posted: 12/30/20 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
With todays 18" and 20" LT E in the 3800-4000 lb range tires the weak link is OEM wheels and OEM rear spring pack ratings.
F250's come with 17" or 18" and 20" wheels so moving up to LT E in a 20" wheel gains a lot of capacity over 17" sizes.
^This. 17s are not viable Heavy load LT tires anymore. Been that way for 5-10years now.
Get some takeoff 18s or 20s if you actually need them.
Or is this just a hypothetical question?
Posted: 12/30/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Royf did a good job of regurgitating the payload specs.
But what he didn’t mention is that the only differences between a 250 and 350 srw apples to apples is a heavier duty rear axle and greater spring capacity.
Combined with the fact that some 3/4 tons are still set at 10klb gvw and even the 10.5 sterling axle in the 250s is rated for almost 10klbs, the physical differences are almost a moot point.
A fact that many cannot understand or refuse to believe.
So Dave just because you think you did something wrong by not specifying a gvw ? Package, it doesn’t matter. Only low end factor on your truck, presume it’s old or base model, is the 17s.
FishOnOne
The Great State of Texas
Posted: 12/31/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I agree go to ebay or craiglists and pick up some 18" tires to get a substantial improvement in tire capacity if it's required.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
ksss
Eastern Idaho
Posted: 12/31/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I think 18's are really the way to go. Many tire options, you get more side wall height to protect the wheels if your off road at all. It is typically pretty easy to find a set of take off wheels at tire stores from guys that have put custom wheels on as Grit Dog stated.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
lenr
Indianapolis, IN
Posted: 12/31/20 11:48am Link  |  Quote  |  Print  |  Notify Moderator
My opinion--yours may vary. Most of below comes from knowledge of 2011 through 2016—recent years may have changed some of this, although I haven’t noticed much as I look at recent years documentation.
The Ford Super Duty brochure showed that the F-250 used a lighter capacity axle from 2011 through about 2015. There was a great debate online with most contending that the same axle is used in both the 250 and 350 SRW for mass production cost saving. It is possible that the lighter axle was used for 2011 Job 1 250s to use up existing supplies from 2010. However, everyone now believes that the axles are the same from at least 2012 and possibly 2011. The F-250 is typically derated to 9900 or 10,000 lb. GVWR even though it can physically handle more. This allows insurance and licensing cost savings in some states. The F-350 since 2011 adds the auxiliary spring and that’s about it other than labeling. So, yes, in agreement with most of above, tires are likely to be the limiting factor. I have noticed in recent years that the 20” tires can get as much as 14,400 GVWR.
JIMNLIN
Oklahoma
Posted: 12/31/20 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
Ford tech guys over on FTE forums say the F250/F350 SRW 6.7 diesel gets the same rear axle with the larger diameter axle shafts.
They also say its the F250 gasser engine with much less torque get the smaller rear axle (smaller diameter axle shafts).
Make sense as axle shafts on the full floater rear ends has nothing to do with carrying weight. The axle shafts just twists the gears.
The two bearings in the axle tube ends carry the load.
 > SRW Tires
