RV.Net Open Roads Forum: Class C Motorhomes: GVWR (lbs/kgs) 14500
 > GVWR (lbs/kgs) 14500
yellowgoode
Battle Creel, mi
Posted: 12/31/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
The 2020 Jayco Grayhawk has a GVWR of 14,500 lbs
Does this include the towing capacity of 7,500 lbs
thanks
BurbMan
Islip, Long Island
Posted: 12/31/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
GVWR is how much the Jayco can weigh, including any weight applied to the hitch by what's being towed, but not including the weight of the trailer. The GCWR is the limit of what the Jayco and trailer can weigh together.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
learntorv
Fulltimer
No, it doesn't.
The "gross combined weight rating" (GCWR) would be the maximum the RV and the towed vehicle can be.
But the "gross vehicle weight rating" (GVWR) is the maximum that the RV itself is designed to carry. When you're towing, there is often "tongue weight" or the amount of weight the towed vehicle pushes down on the rear of the RV. With towing 4-down, I think this isn't a thing. But a tow dolly or trailer would have some.
BFL13
Victoria, BC
Posted: 12/31/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
With trucks they confuse you with "towing capacity" as being the weight of the trailer, but also they have a weight rating for the truck's towing receiver. In some cases, the truck could pull more than the "bumper" receiver is rated for.
With the Class C at 7,500 probably the receiver can do more than that, but check its rating too.
Watch out for their other trick, which is to use a truck with a high GCWR, and then use their lightest weight truck to get the most trailer weight so they can brag about that. You have to weigh your own truck (much heavier) to know what "your" towing capacity really is out of "your" GCWR.
If they used an unloaded Class C instead of one ready to go camping loaded to the max, then you might get the same thing happening.
The "tongue weight" of the trailer on the hitch at the back bumper becomes a greater weight on the back tires with the leverage. So watch for that too, because it is your weight rating for them that counts as well. Trucks have a little drawing and show how to do that calculation for a snowplow up front adding to the weight on the front tires. You can do the same math for the back.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
near Bishop, California
Posted: 12/31/20 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
I suggest you hold off on purchasing a trailer or tow vehicle until you fully understand these numbers.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
carringb
Corvallis, OR
Posted: 12/31/20 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
A GVWR of 14,500 pounds would indicate the Ford chassis, which has a GCWR of 22,000 pounds.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
bobndot
Posted: 01/01/21 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Equally import if towing a trailer , take your trailer to a scale and know what the real loaded for a trip tongue weight is.
A lot of people get a big surprise by how much their trailer tongue weight really is.
wildtoad
Blythewood, SC
Posted: 01/01/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
thanks
Nope. Look for the GCWR rating which is the maximum COMBINED weight for the RV and anything you want to tow.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
wintersun
Monterey
Posted: 01/13/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
GCWR is short for Gross Combined Weight Rating and applied to the total weight of the loaded tow vehicle and the total weight of the loaded trailer when they are "combined".
Gross Vehicle Weight Rating is the maximum weight of the loaded RV along with the weight applied to the hitch by the trailer's tongue.
