RV.Net Open Roads Forum: Fifth-Wheels: Gen Y vs. Reese Goose Box
 > Gen Y vs. Reese Goose Box
work2much
Jackson Ca
Posted: 01/01/21 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
This would be on a 2020 Grand Design Solitude 35' and 2017 Ram 3500 DRW.
Looking for thoughts on these two options to replace the factory 1621 King Pin and Curt Hitch.
Thoughts? Thanks!
2017 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2400 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Busdriver
Shepherdsville Ky 40165
Posted: 01/02/21 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Following
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
TXiceman
Full Time RVer
Posted: 01/02/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Watch using a goose neck box on Lippert frames. They will void warranty if you look at them sideways. And a ball hitch will require safety chains.
Ken
Amateur Radio Operator.
garyp4951
TN
Posted: 01/02/21 06:33am Link  |  Quote  |  Print  |  Notify Moderator
more discussions on this
Hammerboy
Zeeland, MI
Posted: 01/02/21 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Ken
You will have to confirm but I believe at least the Reese is Lippert approved.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
CaLBaR
Ontario, Canada
Posted: 01/02/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Ken
The Reese goosebox is the only one that I am aware of that is approved to use on a Lippert frame.
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
JTrac
Oklahoma
Posted: 01/02/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
We have a Goose Box on our new Pinnacle. I already knew it was approved by Lippert when we bought it last spring but the dealer insisted on calling Jayco before he would install it. No problem. The Goose Box has been available since 2012 if I remember right and you will find very few complaints. I've had all kinds of hitches thru our rv career and the Goose Box is by far the easiest to hook up and leaves my bed clear when I remove the 5 pound ball. Our last hitch was a Hensley Trailer Saver BD3, an absolutely great hitch, but I could no longer remove it without help. The ride we get with the Pinnacle, our truck and the Goose Box is the best we have had and this is fifth wheel number 6 for us.
I think you will find the Gen-Y is not approved and Lippert/GD will tell you it will void your warranty. I'm betting this is because Lippert has a financial stake in the Goose Box. We do use safety chains with ours but no big deal with the puck system in our truck.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR, 4562 payload capacity
Second Chance
Wherever...
Posted: 01/02/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Reese and Lippert are in bed together, so the GooseBox will not void your Lippert frame warranty. I've read quite a few reviews and experiences on multiple forums - everyone seems happy with their GooseBox but I've read several reviews where folks had issues with and replaced their Gen-Y (which will void the frame warranty, anyway).
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
newman fulltimer
louisiana
Posted: 01/02/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
Lippert does not void the warranty with the reese that would be a major fact in my choice
work2much
Jackson Ca
Posted: 01/02/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for al the responses, much appreciate the time you spent helping my decision.
I have decided to order a Reese 20k Goosebox and associated ball/chain hardware.
Yesterday I installed a shock kit on the trailer so I am anticipating a smoother ride overall once the hitch is installed.
Cheers!
