RV.Net Open Roads Forum: Technology Corner: Standard definition tv
 > Standard definition tv
CA Traveler
The Western States
Posted: 01/03/21 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
The HR24 will work. The HR44 requires SWM input so a converter will be needed.
However per above it's unknown what will be available on the 101 satellite if/when DTV drops SD transmission. And I say if/when because DTV is just so transparent about this - NOT.
Note: The HR24 can be configured for SWM (Single Wire Multiplex) and can receive up to 2 channels. The HR44 supports 5 channels.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 01/03/21 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW We use the HR44 at home and in the RV. All of the recorded shows move with the receiver and recording continues in the RV when the dish is up and everyting is HD.
When we drive out of a spot beam the locals have to be changed...
Bill.Satellite
Full-timer
Posted: 01/03/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, the H series receivers are fully backward compatible to SD programming. The HD receiver can receive SD but an SD receiver cannot receive HD.
WHEN/IF DTV drops SD broadcast from the 101 satellite they "should" broadcast some amount of programming in HD from 101. With the H series receiver you would suddenly be able to watch DTV with a dome in HD! The only question is what channels will be available. DTV previously listed a small number of channels that would be available but, to my knowledge, no one has a complete list. NO NETWORKS is almost a certainty but the rest remains a big question mark.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Posted: 01/03/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
A better question is will the 18" dish work once they terminate SDTV.
That dish works on 101 but not 99 or 103 (Wrong bandwidth).
(Antennas are kind of a thing with me.. NOT for Sat TV but for other stuff I sometimes build 'em)
CA Traveler
The Western States
Posted: 01/03/21 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
Bill,
Given what you said I suppose DTV could shift stations to different satellites perhaps for some benefit like more 4K programs? Or other non TV content.
Bill.Satellite
Full-timer
Posted: 01/04/21 05:28am Link  |  Quote  |  Print  |  Notify Moderator
As long as DTV is broadcasting "something" from the 101 satellite the 18" dish will still work, as will a dome. The 101 satellite use the KU band now and will continue to broadcast on that same band if they dropped SD and added HD or 4K or any other programming of their choice.
When/if that happens you would need an HD receiver to receive programming, however.
w4phj
Vero Beach
Posted: 01/04/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
My ancient DTV SD receiver and 18 inch antenna is currently receiving from the 101 just fine.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
djsamuel
Central Florida
Posted: 01/04/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
SD is working fine for me at home.
Picture of Our Trailer
Camplite 21BHS
JimR 1
Custer South Dakota
Posted: 01/04/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies.
So as I understand things my H24-100 will work with my existing 18 inch antenna or the Kingdome.
This is also with the receiver and I assume that would need to be used inline.
DTV SUP-2400 “B Band Converter (BBC) Module”
(for Ka-Lo band up conversion)
So one day I will need to upgrade to HD and get a Traveler antenna or a new dish that I aim or stay in one place that has good WiFi.
What is the future of the carryout antennas? I could get one of those although none of those have HD for DTV as I understand it now.
I do appreciate your help here on this forum, when I call DTV their push is to upgrade and or sell something, also seems harder to get a DTV local satellite provider.
So far the D12 is still working.
Thank You
JimR
CA Traveler
The Western States
Posted: 01/04/21 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
My RF Mogul dish works great for DTV HD.
