RV.Net Open Roads Forum: mounting extra brake lights on 1.5” struts, NO drilling.
 > mounting extra brake lights on 1.5” struts, NO drilling.
Posted: 01/03/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Tape doesn’t require time to “set” or cure. Warm with a torch, heat gun, hair dryer etc and stick on.
AnEv942
CA
Posted: 01/04/21 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
3m tape I use-https://www.amazon.com/3M-3614-15/dp/B002JOVUO0
alot. Only because its available most auto parts to put your hands on. Tenacious stuff.
The lights though unsure as the back doesn't appear its flat enough to tape? very simular housing https://www.amazon.com/dp/B071FGC2JS/ appears same light box, a bit cheaper, LED and semi sealed.
LosAngeles
Los Angeles, CA
Posted: 01/04/21 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the link.... for unusual reasons that I wont bore you with.... i need the extra tail lights to be incandescent.
LosAngeles
Los Angeles, CA
Posted: 01/13/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Update:
My question is - if I bolt into a pre-existing hole in the truck frame, (recent F-350) with a new, stainless steel bolt…. would the frames coating (anodized?) stop it from being a good ground?
see pic of my attempt at grounding (below)
I was advised to avoid drilling new holes into the truck frame… just use pre-existing holes.
so i got the trailer light kit (Blazer C6421 Trailer Light Kit) and I spoke with Blazer previously…..
and they said: I HAVE to ground the white ground wire to the truck frame.
I asked “could I just wire the white ground wire to the 4 pin flat trailer lights plug?” and they said it likely will *not* work…. and i’d need at least a 12 gauge wire … but it is better to ground to the frame.
So I wired everything up today (very simple with the kit) and plugged in… and tested the lights and they did not work at all. Never lit up. Yes the truck lights work fine, and i know that the 4 pin flat plug *is* working fine. (I tested it with something else)
I suspect the anodizing on the frame is the issue. Yes? No?
and if i have to drill a hole…. i was advised to drill into the hitch assembly, *not* the truck frame.
thanks for any guidance.
MY PIC:
https://imgur.com/a/C7g3QCK
jimh425
Western MT
Posted: 01/13/21 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
If you put the wire underneath the washer, the wire will be making contact with the frame. I don’t think anodizing stops current. You could sand the surface to remove it if necessary. It won’t matter if the bolt is SS or not.
deltabravo
Spokane, WA
Posted: 01/13/21 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
LosAngeles wrote:
Update:
The truck frame isn't anodized, nor is the hitch. The hitch is powder coated. The powder coat is preventing the wire from making contact with the bare metal of the hitch.
Connect all the lights to a 4 pin male connector, and plug them in to the truck's 4 pin, DONE.
No, you don't have to ground the lights to the truck frame, you can connect them to the 4 pin trailer pigtail. In fact, connecting all the lights there is the easiest thing to so.
For two tail lights, 12AWG is totally overkill. The people at Blazer aren't very well versed in trailer/truck light wiring if they are claiming you have to use 12awg for a simple pair of tail light, and then also claiming lights won't work when grounded through the 4 pin plug.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
towpro
Compass PA
Posted: 01/14/21 06:11am Link  |  Quote  |  Print  |  Notify Moderator
[image] click here
Here is a more modern looking one.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
deltabravo
Spokane, WA
Posted: 01/14/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Neither of those will work on his Torklift Talon tiedowns, which are aluminum. No one else but me probably noticed that. That was the first thing I noticed in the OP's photo.
AnEv942
CA
Posted: 01/14/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Likely not making contact to metal or the hitch itself isn't grounded due to the powder coating. Could try to touch ground wire to the larger bolt just to see if its making contact. Why 'they' told you cant use trucks ground wire beyond me, less why recommending 12ga.
I gather the included harness does not have a continuous ground wire, short pigtail at both ends, otherwise you'd simply plug it into a 4pin connector.
If the ground wire from light will reach, tap existing ground wire.
Alternatively and what I'd do, you could run a wire between both light ground pigtails to white ground pigtail at plug making it continuous from lights to plug, so when plugged in wala you have ground, no bolting.
Our camper projects page
Posted: 01/14/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Overcomplicating things. Easy button, 4 wires from add on lights, to 4 flat pin, done. If you want to ground, need to make contact with bare metal on truck, also super easy, but no reason to run a separate wire to the truck frame. Heck, the hitch where you hooked might not even have a good ground if the frame and hitch, both painted or coated, didn't rub off enough paint anywhere to make contact.
Avoid extra happy homeowner wiring, like this, I can show you the ball of "electrical improvement projects" wires and plugs I gutted out of the 1986 pickup I'm restoring. None of it worked anymore. Back to just factory wiring, all the lights work fine and I can re-wire a trailer light plug the right way.
