RV.Net Open Roads Forum: Truck Campers: It’s been a good run
 > It’s been a good run
joeshmoe
So Cal
Posted: 01/04/21 02:15am Link  |  Quote  |  Print  |  Notify Moderator
[image][image][image]
Had to remove the lock tab on the right to get the door closed.
* This post was edited 02/10/21 04:56am by joeshmoe *
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
deltabravo
Spokane, WA
Posted: 01/04/21 06:51am Link  |  Quote  |  Print  |  Notify Moderator
anutami wrote:
So if it ain’t broke do I just buy the same set or go with AGM’s as it is a pain the check the water levels and can possibly move them Inside etc.
AGMs for sure. The fact that's in a pain in the neck to check water level is exactly why I replaced my AF batteries with AGM. It's exactly why I killed the wet cell batteries too.
My AGM Battery Upgrade
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
markchengr
Seattle
Posted: 01/04/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
It is OK to put AGM batteries inside an RV. Many people do it.
MORSNOW
Mountain Home, ID
Posted: 01/04/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Any ideas on the best deals out there?
Thnx in advance
Nolan
Hi Nolan, you scared me with your thread title, I thought you sold your Wolf Creek. My 6v Duracell Ultra wet cells in my WC850 are the same age as your batteries, I'm thinking of going with AGM next just for the fact that checking water levels is such a chore. My batteries are tall and just fit in the compartment and making the connections is tuff. My battery box seemed to be about 1/4" short in depth for larger 12v batteries so I went with 6v to get more amp hours. I'm thinking AGM is the way to go.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
Geewizard
WA
Posted: 01/04/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
My two FullRiver DC105-12 batteries are still going strong after 6+ years. One is in the normal battery box and one is under the dinette. They are sealed AGM and will vent only under extreme conditions. I have zero concern that the small amount of hydrogen gas that may be vented will be any danger.
The risk from that battery in an "un-vented box" is far less than that of an oncoming cellphone-reading driver.....IMHO.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
200W solar, MPPT controller, LED lights
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
Kayteg1
California > Nevada
Posted: 01/04/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
There are flooded batteries, who have vent tube as well. Used by several car manufacturer when mounted under the seat. All you need is to drill 1/4" hole in the floor and push vent tubing in it.
anutami
Ramona
Posted: 02/09/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the replies, I was looking at getting the lifelines and almost pulling the trigger, but these blems (don't come with handles) caught my eye , anyone have any experience with DEKA's? Sounds like a pretty good deal, was thinking of getting 3 of them and putting one behind the battery compartment in my WC,
Limited unit's MSRP $328.67 for only $129.99 exchange (if no core + $28.00 core charge)
Hurry when they are gone they are gone **Very limited stock***
*** All have threaded studs***
12 Volt - 105 Amp Hrs - Group 31
Sealed Maintenance Free Deep Cycle Batteries for Marine, RV, EV (Electric Vehicle), Golf Cart, UPS, Inverter, Solar Panel (Photovoltaic), Telcom, CATV and Stand-by Applications
The Deka 8A31DT (8A31DTM) is an American made AGM (absorved glass-mat) deep cycle battery.
The AGM technology allows for a completely sealed maintenance-free battery with no sulfuric acid leaks, no acid clean up, and more power in the same space when compared to conventional batteries. It has an under 2% per month self discharge rate.
These are manufactured by East Penn Manufacturing who also makes batteries for MK Battery.
The Deka 8A31DT (8A31DTM) is a direct replacement for any group 31 lead-acid, GEL, or AGM batteries.
Deka 8A31DT AGM Battery Specifications:
Nominal Voltage: 12V
Amp Hour Capacity @ 20 hr rate: 105 a/h
Reserve Capacity @ 25 amp discharge rate: 210 mins
BCI Group Size: 31
Marine Cranking Amps @ 32* F: 1,000 amps
Cold Cranking Amps @ 0* F: 800 amps
Weight: 69 lbs
Length: 12 15/16 in.
Width: 6 3/4 in.
Height: 9 3/8 in.
Terminal Type[emoticon]tud Terminal
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
zb39
slippery rock
Posted: 02/09/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have used the cheap 6V ones from sams for almost 30 years in 10 different RV's. Best bang for the buck. I don't ever do anything to them and I can get 5-6 years out of them. I also discharge them all the time.
It works for me. If I need more power I will put in more. 6 6V in my last TC. Thinking about putting in 10 for my DP.
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
Kayteg1
California > Nevada
Posted: 02/09/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
My experience as well. Had 4 of them (at $46) put into my bus.
-1 l of coffee every morning
-microwave oven for meals preparation
-long showers, so lot of pump working
-incandescent lights at the time
and the batteries gave me 3-4 days before I had to start generator.
Start loosing capacity at 10 years mark, but I used couple of them till 12 years of age.
Best of 24V battery bank- you can use it for welding.
BradW
Mayor of Flat Rock
Posted: 02/09/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
If you change from 12v to 6v batteries, do you have to change the converter?
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
