RV.Net Open Roads Forum: Truck Campers: It’s been a good run
 > It’s been a good run
Kayteg1
California > Nevada
Posted: 02/09/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
You put 2 of 6V batteries in the row to have 12V, so converter stays untouched.
Posted: 02/09/21 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
OP, maybe look at 6V SLA batteries. Moderate cost, no maintenance + the 6V advantages.
2017 Heartland Torque T29
deltabravo
Spokane, WA
Posted: 02/09/21 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
BradW wrote:
If you change from 12v to 6v batteries, do you have to change the converter?
No. Two 6 volt batteries connected in series is a 12v battery bank.
deltabravo
Spokane, WA
Posted: 02/09/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
anutami wrote:
Thanks for all the replies, I was looking at getting the lifelines and almost pulling the trigger, but these blems (don't come with handles) caught my eye , anyone have any experience with DEKA's?
Yes, I put Deka group 31s in my Arctic Fox 811 in 2015, THey are still going strong.
Here's that upgrade project
I HIGHLY recommend a good amp hour meter too. I run a Victron BMV 712.
Victron BMT-712 in my AF 811
joeshmoe
So Cal
Posted: 02/10/21 04:48am Link  |  Quote  |  Print  |  Notify Moderator
anutami wrote:
Limited unit's MSRP $328.67 for only $129.99 exchange (if no core + $28.00 core charge)
12 Volt - 105 Amp Hrs - Group 31
Sealed Maintenance Free Deep Cycle Batteries for Marine, RV, EV (Electric Vehicle), Golf Cart, UPS, Inverter, Solar Panel (Photovoltaic), Telcom, CATV and Stand-by Applications
The Deka 8A31DT (8A31DTM) is an American made AGM (absorved glass-mat) deep cycle battery.
The Deka 8A31DT (8A31DTM) is a direct replacement for any group 31 lead-acid, GEL, or AGM batteries.
Deka 8A31DT AGM Battery Specifications:
Nominal Voltage: 12V
Amp Hour Capacity @ 20 hr rate: 105 a/h
Reserve Capacity @ 25 amp discharge rate: 210 mins
BCI Group Size: 31
Marine Cranking Amps @ 32* F: 1,000 amps
Cold Cranking Amps @ 0* F: 800 amps
Weight: 69 lbs
Length: 12 15/16 in.
Width: 6 3/4 in.
Height: 9 3/8 in.
Terminal Type[emoticon]tud Terminal
These are the same as mine. Same specs and dimensions. Made by East Penn w/Duracell label. I paid $180. $130 is a dang good price. Hopefully they have a decent warranty. At that price, get 3 or even 4 of them. Find room if you have to. Sure would be nice to have 420Ah's.
One thing they seem to do well is recover quickly.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
silversand
Montreal
Posted: 02/10/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
Start loosing capacity at 10 years mark, but I used couple of them till 12 years of age.
....my old Maxtanks (AGM) are still in operation at 13 years last year (2020). I suppose replacement will be needed soon.
Silver
markchengr
Seattle
Posted: 02/10/21 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
I have very limited clearance at the top of my 2 battery compartments so I switched to two 6 volt AGM's not only due to no maintenance but also because they are any-position batteries so I can have the terminals facing outwards for much easier hookup.
rickjo
SW New Mexico
Posted: 02/11/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
6v Golf cart batts have performed so superior to 12v whatever. I can't imagine any other way now. The deep discharge capability is non-destructive on purpose.
Rick
2019 F-350 4WD Crew Cab DRW 6.2 l gas engine (6500 lbs cargo capacity!)
2007 LanceMax 1181 loaded, King memory foam mattress (driver's side locker omitted).
"Leave the trail a little better than you found it."
btggraphix
Golden, CO
Posted: 02/11/21 10:04pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve been happy with the pair of G31 Dekas we bought about 8-9 years ago. I’ll probably replace them soon to be safe but they’ve worked really well. They are plugged in in our Lance outside 24/7/365 in the mountains and have been fairly regularly abused and run pretty low.
2006 LanceMax 1191 - loaded and well-used
2005 C4500/Kodiak 4x4, GVWR 17,500
Bert the Welder
Van. Island
Posted: 02/26/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Since it's kinda on topic, what is it that makes the 6v GC batt's better then 12v ones? and does the "better" status still apply if they are AGM?
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
