RV.Net Open Roads Forum: Fifth-Wheels: slideout adjustment
 > slideout adjustment
hitchikerman
Linden
Posted: 01/04/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I have a new to us 2020 Cougar 315 RLS which has a common floor plan. Well when we first received it you could open the refrigerator door with the slide in. Well after running the slide in and out the refrigerator hits the island and cannot be open all the way, Just was wondering how this happen
jdc1
Rescue, Ca
Posted: 01/04/21 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Lol. Evidently the slide wasn't fully retracted when you thought it was.
ford truck guy
Pennsylvania
Posted: 01/04/21 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Although the above could be the reason... I had the same issue with my recent fiver... The residential fridge was not secured properly and moved about 1/4 of an inch towards the island..
It was an easy fix for me... you can do it, OR the dealer will handle under warranty
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
MFL
Midwest
Posted: 01/04/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
The slide has to come in far enough to allow a good fit to the seals. I don't know how your island is fastened, but is there a chance it may have moved. This just really isn't making sense. If the fridge isn't hitting against the island, when fully retracted, it is not a real issue, but rather an inconvenience.
Slides can be adjusted, for small corrections, but does not seem to be the problem IMHO.
Jerry
MFL
Midwest
Posted: 01/04/21 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I agree, if the fridge can be moved a small amount, and then the door will fully open, that may be best option.
Jerry
hitchikerman
Linden
Posted: 01/04/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Oh ok I have to take it to the dealer soon...I'll just have them look at it...thanks
ford truck guy
Pennsylvania
Posted: 01/04/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was easy... I took off the small plastic cover that went from side to side on the bottom covering the lower front of the fridge.
There were 2 rather small and thin 90* angle brackets that were secured into the floor and the front for the fridge leg... I replaced them with more of a Heavy Duty bracket and pushed the fridge back about 1/4" before securing...
