RV.Net Open Roads Forum: Travel Trailers: Comparing New Tires for trailer
 > Comparing New Tires for trailer
Taffy.C
MN
Posted: 01/04/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Hi There. I'm replacing the ST185/80/13 tires on my trailer and have the option of either Carlisle or Power King Towmax brands. I'd welcome any advice on how these brands compare?
Thanks,
Daniel.
* This post was edited 01/04/21 05:57pm by Taffy.C *
2003 Explorer Limited 4X4 V8 Advancetrac 3.73 Axle
Jayco Kiwi Too 22U
Hensley Arrow
Prodigy
South of Lone Pine, California
Posted: 01/04/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
What are the load ranges (B, C, D etc.) and max weight of the tires you are considering? What is the weight of your trailer wet and loaded?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MFL
Midwest
Posted: 01/04/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Does it have to be one or the other? There are better options out there. To name a couple, Provider STs, and Good Year Endurance STs, that can easily be ordered. To answer your question, I'd get the Carlisle, if HD with M speed rating.
On edit: The better choices I mentioned may not be available in that exact size.
Jerry
* This post was edited 01/04/21 07:04pm by MFL *
Boon Docker
Posted: 01/04/21 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure about Power King. I have been using Carlisle for the past 15 years with no complaints.
Yaj
The Milky Way Galaxy (Fort Myers, FL)
Posted: 01/04/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
They don’t call them “blowmax” for no reason!
time2roll
Posted: 01/04/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Check the speed rating.
675w Solar pictures back up
Boon Docker
Posted: 01/04/21 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Speed rating for the Carlisle ST185/80/13 Radial Trail HD is "M"
MarkTwain
Northern, Ca. , USA
Posted: 01/04/21 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Daniel.
Had nothing but tire problems with the Towmax.[emoticon] Is it possible to go up in your tire size, better towing and load capacity.
Taffy.C
MN
Posted: 01/04/21 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice - very helpful. The good year's don't seem to be available in my size so I'll go for the Carlisle HDs. Don't really want to up the wheel size at present as I'm trying to keep the cost down.
Jim2007
Greeley, Colorado
Posted: 01/04/21 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
Hi ... I have Goodyear Endurance and am happy with them. I set psi at 70. My fifth wheel suggests 65to 70 psi.. I have about 20K. Miles on the tires. Jim2007
TV: 2016 Dodge 2500 Diesel
Rig: 2013 Heartland, Sundance, 5th wheel
