RV.Net Open Roads Forum: Tech Issues: Slide rubber
 > Slide rubber
dutchev
tilton nh
Posted: 01/04/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
My rubbers on top of each slide has deteriorated. sides are fine. any suggestion other that totally replacing them. need to keep that rain out
JimJohnson
Texas Hill Country
Posted: 01/04/21 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
depends on the level of deterioration whether they are salvageable.
Not pointing a finger at you, but you can tell who has high use of their RVs and who are 'grab & go' weekenders. Typically folks who use their RVs a lot, do the needed maintenance; weekenders don't. Cleaning and UV protection is critical; especially the rubber and plastic parts. There are plenty of high-quality products on the market. If you don't make the time to use them, you will be opening your wallet further doing repairs.
Lynnmor
Red Lion
Posted: 01/05/21 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I have no suggestion since they are spent.
2oldman
NM
Posted: 01/05/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I'd replace. Not a fun job, but not terribly difficult.
BarneyS
S.E. Lower Michigan
Posted: 01/05/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from DIY.
craig7h
Branson MO area
Posted: 01/06/21 03:27am Link  |  Quote  |  Print  |  Notify Moderator
If they are not doing the job, its time to replace. The water leakage will do more harm than the time spent replacing. Check out Steele Rubber for replacement. https://www.steelerubber.com/
Itasca Meridian SE 36g
Road Master Tow Dolly
 > Slide rubber
