RV.Net Open Roads Forum: Fifth-Wheels: Slide out drifts open
 > Slide out drifts open
todd j
pride,la.
Posted: 01/05/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2009 Sierra by Forest River 335QBQ. It has 4 slides. The slide out on the fifth wheel end (bedroom) drifts open while the camper is just sitting there. It is connected to power. The slide outs do not work independent of each other. As one reaches it's final position the next starts to move. It's not like a could block a valve to the affected slide and stop it.
Any ideas????
Thanks
BurbMan
Islip, Long Island
Posted: 01/05/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a hydraulic check valve is letting fluid seep by and allowing the slide to extend. The quick fix is to get a pair of these locking poles to keep the slide closed.
Our last Terry came from the factory with these poles to take the pressure off the mechanism keeping the slide closed when going down the road. Just have to remember to remove them prior to opening the slide.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
JIMNLIN
Oklahoma
Posted: 01/05/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
A previous 5th wheel trailer we had would creep out. Didn't notice it sitting till the 1st trip when I checked the outside mirror. Lordy it was out about 10" or so. I broke the wife's broom stick off to the right length where it would wedge in at the top/center inside the trailer and hold the slide in. After the trip I made a better pogo stick. Years back many 5er trailers with a slide or tip out came with a pogo stick from the factory to keep the slide out in while traveling.
Dick_B
Palos Heights, IL USA
Posted: 01/05/21 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
We use two pogo sticks to keep the slide in even tho it is electric.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
ford truck guy
Pennsylvania
Posted: 01/05/21 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
We had a 1998 Holiday Rambler Alumalite that came with 2 slide out enforcing bars that had a tensioner built in.
There was a piece of steel plate on the backside of the slide room that these set on
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
todd j
pride,la.
Posted: 01/05/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Are you saying the residual pressure is causing it to move? Seems like the pressure would equalize at some point and movement would stop.
I agree locking poles, Pogo sticks or some other type of pole will stop movement. it did not do this when we first bought it. The rear slide (2) is a bunkhouse so there is no way to get back there once slides are pulled in.
I've never had any trouble with it moving while traveling.
BurbMan
Islip, Long Island
Posted: 01/05/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
As the hydraulic pump moves fluid through the system that causes the slide to retract, there is a check valve that stops fluid from flowing the opposite way once the pump stops. Not sure I would call it "residual pressure" although I think you get that the effect is the same.
todd j
pride,la.
Posted: 01/05/21 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Where is the check valve? In the pump?
BurbMan
Islip, Long Island
Posted: 01/06/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
No idea, and that's only my guess as to what could be wrong. You could also have a leaking seal, damaged hose, etc. Lippert made several types of slide systems for Forest River, I'm guessing yours is hydraulic because of the way they all the slides work together.
Maybe start on the Forest River Forum and see if other owners maybe had/fixed a simliar problem.
ChuckSteed
Mtn Home, Idaho
Posted: 01/06/21 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Hyd slide out creeping out when closed is caused by
1. Air in system. Cycle slides in and out 3 to 5 times to purge air
2. Internal or external leak on slide actuator
3. Hydac solenoid valve .. only one for hyd slides nit fully closed in manual override mode CW) or sticking valve
DO NOT use a bar or anything else to keep hyd slides closed .. 2000 psi is used to keep slides closed or open and if leak is internal on actuator your can tear up your slide by locking in place
