RV.Net Open Roads Forum: What is the best safe for a TC?
 > What is the best safe for a TC?
jaycocreek
Idaho
Posted: 01/06/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I see one TC that comes with a floor safe which seems like a good idea for those on long vacations/fulltiming or just spend a lot of time in their TC away..Mine is an older TC but I do want to get a safe for it whether portable or mounted..
What do you use or do you?
jimh425
Western MT
Posted: 01/06/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
I think any true safe would be far too heavy and take up too much space. The pistol safes like gunvault are “ok”, but they still take up a lot of room. I think the best option is a combination cable lock run through a solid D ring mount would be the best solution for most people. Any prepared thief to easily defeat any safe, so I think it’s best to focus on the casual thief. I’ve used all, but like I said, I lean toward the cable lock.
jaycocreek
Idaho
Posted: 01/06/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
I have one fairly small fireproof safe we used before we got our gun safe but it is as thick as it is big with no handles..There's really no way to secure it..When we had the fifth wheel and travel trailer there was plenty of room to hide and secure a safe,not so much in our truck camper..I'm thinking either really small for the pull up cabinets next to the cabover bed or something anchored in a closet...Kinda lost on this one..
Kayteg1
California > Nevada
Posted: 01/06/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I've been using file safe placed on the back floor of our SuperCab.
It is light enough for me to carry it in and out. Maybe not extreme safety, but I figure out nobody is going to deal with truck alarm and walk away with it in day light.
JimK-NY
NY
Posted: 01/06/21 09:51am Link  |  Quote  |  Print  |  Notify Moderator
When I was a fulltimer I carried all my important papers, passport, non-electronic tax records, etc. I found two extremely well hidden areas for storing this paperwork. I would not have had room for a safe or anyway to hide it. A safe might have protected against the risk of fire damage but would have greatly increased the risk of theft.
brholt
Seattle
Posted: 01/06/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
As an alternative consider a “console vault” for your truck. These provide pretty good security and the one we installed was very easy to put in.
Just google “console vault” for options
thedavidzoo
Tucson, AZ
Posted: 01/06/21 09:58am Link  |  Quote  |  Print  |  Notify Moderator
We bought this gun safe https://www.amazon.com/gp/product/B07LBC4YL4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It is large enough for important papers also, 3 ways to unlock, has a cable that we attached to a big eyebolt in the bottom of the camper pantry. We move it into the house to its own eyebolt in our master closet. Works fine for us, not too heavy.
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
Dick_B
Palos Heights, IL USA
Posted: 01/06/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
We have an embedded wall safe on the back wall of a closet in our stick house. Doesn't take up any space and is relatively safe in that lots of damage would have to be done to get it out of the wall taking up too much time for an amateur. Nothing one can do to keep out a pro.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Bumpyroad
Virginia
Posted: 01/06/21 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
I bolted down a pistol safe in my RV. if you want a fireproof safe, additional problems will ensue. unless you are a full timer with no other options, you shouldn't need a fireproof one anyway.
bumpy
theoldwizard1
SE MI
Posted: 01/06/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
The "best" safe is don't take valuable with you !
Realistically, you aren't going to take the time to put a laptop and hard drive inside for a meal out. LCD TVs under 32" are ridiculously cheap (meaning a thief would be lucky to get $10-$20 for one).
I would suspect, most people who take a gun with them are going to carry it.
