RV.Net Open Roads Forum: Tow Vehicles: Built-in Genset on 2021 F-150
Search only in Tow Vehicles
 > Built-in Genset on 2021 F-150
Page of 5
StirCrazy
Kamloops, BC, Canada
Posted: 01/06/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
would be nice if it was in the diesel f350, but would be kind of a pain if you couldn't just use your key fob and start it and actavate it. would suck to have to go out and start the truck then push a button.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Turtle n Peeps
California
Posted: 01/06/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Meh, what's old is now new again..
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
spoon059
Just north of D.C.
Posted: 01/06/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Groover wrote:
The hybrid is rated to pull up to 12,700lbs and in the tests that I have seen outpulls everything else on the road short of big diesels.
I'm not worried about max pull, I'm worried about PAYLOAD. I'm not sold on lighter half tons claiming 3000 lbs payload. I prefer the solid construction of a 3/4 or 1 ton when towing my family of 5 plus dogs.
2015 Ram CTD
2015 Jayco 29QBS
thomas201
Eastern Panhandle WV
Posted: 01/07/21 04:50am Link  |  Quote  |  Print  |  Notify Moderator
Big detail for us, the truck needs a stack or a hose to keep the exhaust fumes away from the camper. Esp if you stay hitched, or you neighbor is close.
If you need it on a 250/350/450 diesel or gas there are lots of upfitters that will get it done. PTO or under hood, I have used/seen both generators and hydraulic drives on pick ups.
It is only money, common in oil field applications.
Tvov
CT
Posted: 01/07/21 05:10am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Not sure exactly what you mean, but in the link in the original post they say that the truck and generator can be controlled by your smart phone - no need to go out to the truck.
2008 F-250 CrewCab 5.4L,
Tvov
CT
Posted: 01/07/21 05:17am Link  |  Quote  |  Print  |  Notify Moderator
I don't think it is any different than having a separate "camping generator". I don't think I've ever seen a stack on a 2 or 3,000 watt Honda at a campground.
Emissions would be an interesting thing - I wonder if the truck engine actually has less emissions than a stand alone camping generator?
The specs and capabilities of the the generator F150 are very intriguing.
mkirsch
Rochester, NY
Posted: 01/07/21 07:02am Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
I'd much rather wear out a $600 inverter generator than a $40k truck.
When is the last time you've worn out an engine on a vehicle?
Groover
Pulaski, TN
Posted: 01/07/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I can't think of any small generator that has either EFI or a catalytic converter so I would bet on the Ford being cleaner. TFL conducted a fuel consumption test that showed the Ford being on par with the best Honda generator available so CO2 emissions are in line too. Not only that but the Honda EU7000 costs much more than the option in the Ford, is only rated for 5,500 watts continuously vs 7,500 watts for the F150 and the Honda weighs 261 lbs dry. I wouldn't want to lift one of those in and out of my truck bed very often. Finally, the Honda has to run continuously since it doesn't have any battery backup.
Groover
Pulaski, TN
Posted: 01/07/21 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Payload will be an issue for many. The crewcab F150 4wd apparently weighs around 6,000lbs empty but it does come with max payload package which gives is a gross weight of 7,850lbs for about 1,800lbs of payload. I would like to see the weight distribution and how much extra capacity the rear axle has. I am speculating that the GVWR may be conservative to keep the truck in the "half ton" category and that it would handle its rating easily.
Regardless, if the option catches on the tech could easily be applied to heavier trucks and I would be more surprised than not if that doesn't happen soon. Hopefully with a bigger battery to boot.
valhalla360
No paticular place.
Posted: 01/07/21 10:25am Link  |  Quote  |  Print  |  Notify Moderator
If you are looking at it for rare exceptional use (ie: the park power goes out), sure.
But if you are using it 100nights per year, that's could easily be an extra 1000-1500hr per year under less than ideal very light loads. If you "drive new every 2", not a big deal but that could be the equivalent of an extra 50-100k miles per year, so it could change the equation a lot in terms of how long an engine lasts.
PS: I didn't catch it in the article but how much are they charging for this system?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Page of 5
