RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Heating pads
Swope7896
87047
Posted: 01/06/21 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking of placing heating pads on my grey and black water tanks, but I'm not sure what kind of watts/volts to use. Has anyone else done this? Any help or advice would be greatly appreciated!!
Williams AZ area
Posted: 01/06/21 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
RV tank heater pads use 4 to 10 amps per hour. Will you be plugged in to 120 volt power or do you have adequate batteries?
SDcampowneroperator
South Dakota
Posted: 01/06/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. old waterbed heating pads with thermostat worked well The attachment of them to the EPDM tanks was troublesome, theres few caulks that can do the job. We used a butyl rubber caulk
phemens
Montreal, Canada
Posted: 01/07/21 06:30am Link  |  Quote  |  Print  |  Notify Moderator
The one I use for my battery bank is a waste tank heating pad and it draws 6 amp at 12v. It is intended I believe for 49 gallon tanks.
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
time2roll
Posted: 01/07/21 08:51am Link  |  Quote  |  Print  |  Notify Moderator
www.ultraheat.com
675w Solar pictures back up
Second Chance
Wherever...
Posted: 01/07/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
What kinds of temperatures are you experiencing/expecting? Due to the mass in the fresh and waste tanks, it takes a lot longer for them to freeze than it does for your water lines, water pump, etc. to freeze. We have weathered temps in the 10F range at night without tank heaters and without the tanks freezing (enclosed, heated underbelly on a fifth wheel).
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Williams AZ area
Posted: 01/07/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Has OP deserted us?
rlw999
Washington State
Posted: 01/07/21 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
With the tanks enclosed in a heated underbelly, wouldn't you expect them to stay unfrozen indefinitely?
Williams AZ area
Posted: 01/08/21 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Provided you don't get some crazy low temperature, yes.
Second Chance
Wherever...
Posted: 01/08/21 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
I was merely making the point so the OP (who doesn't seem to have returned to the thread) would know it's not an issue if you have a heated and enclosed underbelly. In answer to your question, yes, I would.
Rob
