RV.Net Open Roads Forum: Tech Issues: Renogy Controller w/BT
 > Renogy Controller w/BT
campermama
Here and There
Posted: 01/07/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Help!!
So yesterday I upgraded my solar controller from a cheap basic Go Power PWM 30A to the Renogy Rover 40A with BT. Easy install. Was working great all day.
This morning the BT has no power going to it! I unplugged, replugged and nothing. Any ideas??
2018 Dodge Ram 3500 Laramie,SRW,CTD,4x4,Long bed
2020 Jayco eagle ht 274ckds
My Adventure Blog:
https://roaddivaontheroad.blogspot.com/2020/03/getting-ready.html
2oldman
NM
Posted: 01/07/21 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
How are your batteries?
dedmiston
The West
Posted: 01/07/21 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hey there.
I don't recall the model number of my Renogy BT controller. It's external though. Is that the same as yours?
I've been running mine for close to two years now, if I recall.
I had one occurrence about a year ago where I lost connectivity. It was a pain to remove the screws and the cover to unplug it, but disconnecting & reconnecting reset the controller and reestablished the BT connection.
I don't know any other way to reset that controller. I wonder if yours could be faulty?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Yosemite Sam1
Under the pines.
Posted: 01/07/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Renogy's controller connectors would easily disconnect.
The clip to cable being tightened by a small screw are both weak.
Check this out every time you move it (mine is portable). This often happens to me and it's frustrating.
Near DVNP, California
Posted: 01/07/21 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t remember my model number or how long I’ve used it, but I’ll check...and on resetting too.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
campermama
Here and There
Posted: 01/07/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Guess I wasn't very clear?
Controller works fine!
Problem is the BT-1 bluetooth module
is not working. It has no power. It was working fine then all of a sudden no power.
I have reset the controller, didnt fix it. I dont know what else to try.
Thanks!
dedmiston
The West
Posted: 01/07/21 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
Hey Friend. Did you disconnect the BT module from the main controller to reset it? That's what I did to reset mine.
time2roll
Posted: 01/07/21 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
This is all I see in the manual:
3. How to Connect via Bluetooth
Please ensure your device’s Bluetooth setting is turned on.
Select:
Configuration > Search Devices > Device
The green indicator on the BT-1 will turn on once it has successfully connected to the power.
The blue indicator on the BT-1 will blink once it has successfully connected and during communication.
It is the BT-1 that is not turning on right? Only 3 possibilities. Problem with power to the controller connector, problem with the cable, BT-1 is defective. I would be calling Renogy.
675w Solar pictures back up
StirCrazy
Kamloops, BC, Canada
Posted: 01/08/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
I cant remember off hand, is there a light on the modual to indacate power? I installed mine in a closet and cant remember off hand. I know if the batteries are disconected from the controler it wont power the bluetooth, other than that I would guess it is defective as was mentioned.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
