RV.Net Open Roads Forum: All in one solar / shore converter charger
 > All in one solar / shore converter charger
moonlitsouls
Everywhere
Posted: 01/08/21 03:38am Link  |  Quote  |  Print  |  Notify Moderator
Hope all is well
The stock shore power charger/converter in my RV is a Progressive Dynamics 45 amp converter. The model # is PD4045KA.
I will be upgrading to lithium and Progressive Dynamics advised me that i can actually modify this converter by pulling a "jumper" and it will be able to charge my upgraded lithium batteries
There is also a solar charge controller installed by the dealer for the first owner , its a gopower unit with a 190w panel, my plan is to add another 190w panel , upgrade the solar charge controller and eventually the stock converter as well (since its not really made for lithium)
my question is this
is there another converter/charger that can do it all?
it would be nice if i could find a charger converter that can control shore power, solar power, and that also has an automatic transfer switch to run the generator based on preprogramed settings
for example, if the batteries are run down below a certain percentage and there is no incoming solar, ideally the generator comes on automatically
im trying to figure out how to tie all this in together with the least amount of equipment bc im starting to see that i may be thinking i need to buy a lot more stuff than i actually need
would appreciate some guidance
thanks
adam
* This post was edited 01/08/21 03:53am by moonlitsouls *
CA Traveler
The Western States
Posted: 01/08/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
When that one unit fails then what?
Solar power varies considerably during the day. What constitues no solar? 1A charging? So do you want the gen on at cloudly 10:00am with the potential for significant sun the rest of the day?
I don't know your plan. Mine is to get the batteries recharged by sunset. A flooded/AGM plan is to charge in the AM if conditions suggest and let solar finish the charging. With LI which can be charged at a high rate waiting might a good option. Boondocking charge when you want, CGs not so much.
Are you aware that LI voltage remains high until they reach 10%+ SOC with minimum drop? You might want to look for gen start based on SOC.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 01/08/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
BTW My RV has automatic gen start based on voltage.
I've never used it.
valhalla360
No paticular place.
Posted: 01/08/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
I few thoughts:
- A single all in one unit...if it fails, you have nothing. If you have separate battery charger systems, if one fails, you can limp along with the other.
- The converter and solar charger provides 12v DC to the batteries. A generator transfer switch is used to select the source of 120v AC (either shore power or generator power)
- Most portable generators do have a DC output but it's really only useful as an emergency backup. They are usually maxed at 6-8amps and unregulated. In a pinch, you can limp along but far better to run the generator plugged into the 30amp AC plug and let the converter charge at 40-60amps of regulated DC power.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
vermilye
Oswego, NY, USA
Posted: 01/08/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
While I prefer to keep my solar controller & converter as separate devices, there are products that combine them. One example is the REDARC TVMSKIT05-NA RedVision & Manager30 Kit. This in now available in a 120V version for the US market, although at over $2000.00, far more expensive than separate devices.
Jon Vermilye My Travel Blog
My Photo & RV link blog
theoldwizard1
SE MI
Posted: 01/08/21 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
moonlitsouls wrote:
I will be upgrading to lithium ...
it would be nice if I could find a charger converter that can control shore power, solar power, and that also has an automatic transfer switch to run the generator based on preprogramed settings
Not exactly what you are asking for but I think it is a better solution.
Get a new inverter/charger like a Samlex EVO-212 (it has charging profiles for flooded, AGM and LiFeSO4; other makes/models are also available) that has a built in transfer switch and automatic generator start.
Remove your converter. Connect the DC fuse panel, the solar charger and the inverter/charger directly to the battery bank.
You're done !
phemens
Montreal, Canada
Posted: 01/09/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I have the Samlex 3012, it does everything you're asking it to do, and it's built like a tank, solid components that IMO are less likely to fail than individual devices (charger, inverter, etc).
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
moonlitsouls
Everywhere
Posted: 01/09/21 11:28am Link  |  Quote  |  Print  |  Notify Moderator
**** that thing is a beast , i just read the manual for like 15 min and i must be becoming a dork bc it was fun lol
moonlitsouls
Everywhere
Posted: 01/09/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
You're done !
thanks a lot , samlex seems to be putting out some quality stuff, i looked through their products on amazon to see how theyre being reviewed. the EVO line has a lot of what i need!
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 01/09/21 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Washoe Medical Center tried auto-management start-synchronize-parallel system in Reno Nevada.
Result?
A 12 cylinder Caterpillar engine and one megawatt KATO generator tore loose from its mounting, ripped its way through a cinder block wall and ended up on the curb on 4th Street in Reno, Nevada. Total loss for the whole assembly.
