BobsYourUncle
Calgary Alberta Canada
I've overnighted many times in snow and ice, but have always found level ground and left my TT hooked up.
Chocking on ice is not easy, as the risk of sliding is high.
I carry a truck full of hardware wherever I go so my inclination would be to get one of my many blocks of wood I carry, along with some 4 or 5 inch decking screws and screw blocks of 2X8 or 2X6 into the ground against the tires. Assuming you are not on pavement. A few screws through the blocks into the ground and it's not going anywhere. Do both sides. You could screw your chocks to the blocks if needed.
In addition to that, if it will reach, crank your hitch jack down without using a block. The pipe will dig into the ice and provide an anchor point.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
profdant139
Bob, those are good suggestions. But if you crank your jack down to serve as an anchor point without the jack wheel, and if the trailer then shifts a little after you chock the wheels and unhitch, the stem of the jack can be bent a little, making it impossible to retract the jack.
Please don't ask how I know this.
The good news is that replacing a bent jack is not that expensive or difficult.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
South of Lone Pine, California
Lots of good ideas above. Very informative.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
JRscooby
Indepmo
profdant139 wrote: Bob, those are good suggestions. But if you crank your jack down to serve as an anchor point without the jack wheel, and if the trailer then shifts a little after you chock the wheels and unhitch, the stem of the jack can be bent a little, making it impossible to retract the jack.
Something I always think of when I see/hear of a RV trailer set down with out wheel on the jack; Often when I want something rigid I make a triangle, because once set, as long as the length of a side does not change, the angles can't change. Now in my mind I see a* triangle, where the weight meets ground at tire, (A) where the jack meets ground, (B) and where jack is attached to tongue. (C). Now the point A should be set so it can't move when you unhook, or the trailer can roll away. And the distance A-C is set when trailer built/loaded. The angle at C is set when the jack is mounted. When you crank the jack down to unhook, you set the lengths of A-B and B-C. Most trailers, your done, nothing changes until ready to hook back up. But a RV trailer, we want the floor level, so we start changing the length of B-C. With a wheel at B, that lets the length A-B also change, no issue. But the angle at C takes more force as the length A-B resists the change in length. Will the jack/jack mount take that strain? Most times. But can you be sure all the jacks that get bent is because the jack was holding the trailer in place?
*I said 'a triangle' but there are the same triangles on each side of the trailer. And a tandem trailer has 4 triangles. But they are all putting stress on the same point.
Skinny D
California
cougar28 wrote: Just get you some #10 1/2 long hexed head sheet metal screw and screw into the bottom of the rubber chock. Those will bite into the ice and keep them from slipping. You can always remove them for better weather camping.
Do you mean to use the hex head as the ice stud pointing down, with the threaded party of the screw biting up into the chock?
I had considered running screws through a 2x6 with just enough of the threaded tip pointing out to act as the ice studs. You think the hex head would bite better?
And once I got 6' of 2x6, I'd still have enough room to pull up on my levelers for full leveling.
Skinny D
California
noteven wrote: To release them drive off and then give them a couple gentle hits with something heavy - chunk of firewood - to break them free. If you overdid the hot water freeze in you might have to use hot water to thaw them free again.
My 2x6s froze to the ground last time... only seemed to contact ground/ice on 1 of 6 sides, but I COULD NOT break free a few of them. The ice was stronger than the doug fir and I just hammered off pieces of wood, and ended up just leaving some wood frozen to the ground.
pianotuna
Regina, SK, Canada
Skinny D wrote: My 2x6s froze to the ground last time... only seemed to contact ground/ice on 1 of 6 sides, but I COULD NOT break free a few of them. The ice was stronger than the doug fir and I just hammered off pieces of wood, and ended up just leaving some wood frozen to the ground.
That's why I carry a crowbar. DAMHIK
Sand on the ground where the contact points between the RV and the ground are.
Regards, Don
cougar28
Lowell,AR USA
Skinny D wrote: cougar28 wrote: Just get you some #10 1/2 long hexed head sheet metal screw and screw into the bottom of the rubber chock. Those will bite into the ice and keep them from slipping. You can always remove them for better weather camping.
Yes using the head as the ice stud. Better -can't say for sure but I've used many of them over the year for ice studs in off road tire -atv-sxs and dirt bike. You can also buy them specifically for just that.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
BurbMan
Islip, Long Island
Think opposite...when we camp on the beach, you can't use any kind of blocking in the sand to raise the low side...so we use a shovel and dig out under the wheels to lower the high side!
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
jdc1
Rescue, Ca
Use your golf shoes instead of wheel chocks.
