davehultin
Fargo, ND 58104
We're getting our trip plans lined up for summer, and one trip will have us coming from Wisconsin, then going around Lake Michigan, and then heading towards Ohio (to Cedar Point in Sandusky). We did this route once before and went through some very congested (and kinda sketchy!) areas of Chicago.
Looking for advice from any veteran travelers of this route, what's the most efficient way to bypass the busyness and congestion of the Chicago area?
Dave Hultin
2010 Ford Expedition, 2018 Gulfstream Cabin Cruiser 28BBS
C.B.
APPLETON WI USA
I've taken I90 South out of Madison to I39 south to I80 East to I80/90 east.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~EMS-HW50C~
Butch/Barb=2013-Cedar Creek 36CKTS
Kris/Katy=2006-Cherokee 32B
angler
WI
Depends where in Wisconsin you are coming from. The rockford route works out well.
If you are closer to the lake in Wisconsin and going south 294 around Chicago and then the 80/90 east route.
2020 Jayco 34RSBS
2002 Tiffin Allego Bay
2010 Keystone Springdale 29bhssr
1998 Jayco Lite 244
Thom02099
Loveland,CO
Depends on how you define "efficiency". Are you looking for a more leisurely route? Do you have the time to go a bit further out of the way in order to avoid Chicagoland?
Not a fan of driving through any part of the Greater Chicago area. If it were me, I'd take I-39 south to US 24 east all the way across Indiana to Fort Wayne, I-469 around Fort Wayne and then pick up US 24 again to I-90 and on to Sandusky.
While I've not done this route as a continuous trip, I've done most of this in segments, from point A to point B. US 24, for me, was a good alternative to avoiding both Chicago and Indy. Only portion I've not done is in Ohio, but I suspect it's not a lot different from the Indiana portion.
2007 GMC Sierra SLE 3500HD Dually
2016 Coachmen Catalina Legacy Edition 243RBS
2007 Keystone Outback 25RSS - R.I.P.
Mfan
Otsego,Mi
Can you adjust your time to go through? After the day rush, not a bad trip through town
pianotuna
Regina, SK, Canada
Hi,
There used to be a ferry you could take across Lake Michigan.
Depending on where in WI you are starting, you could take I-39 then turn east on I-55, then continue on #14
https://freecampsites.net/#!41.509536298........Distance=25&routeIndex=0&roundtrip=false
edited 01/09/21 02:25pm by pianotuna *
Regards, Don
obgraham
TriCites WA
Quote: Not a fan of driving through any part of the Greater Chicago area. If it were me, I'd take I-39 south to US 24 east all the way across Indiana to Fort Wayne, I-469 around Fort Wayne and then pick up US 24 again to I-90 and on to Sandusky.
I've done that route, and it is certainly less congested. But it does involve a large number of towns, cities, and stop lights. In a car it is okay, but in a big RV it can be tedious.
I'd rather choose my time, and just bear with 294.
Edd505
Elephant Butte, NM
I39 S to Joliet Hy30 E That was the truck Chicago bypass back when. It does go through lots of little towns.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
hornet28
Muskegon
If you will be leaving from somewhere in Wisconsin C.B.s route down I-39 to I-80 is the way I avoid Chicago. I also plan to go thru early in the a.m. or late at night.
If you're leaving from Fargo you could do the route I'll post a link to. This route is only 53 miles longer but about 3 1/4 hrs longer. This route avoids Chicago plus Minneapolis which I hate worse than going around the bottom of Chicago.
https://www.google.com/maps/dir/Fargo,+N........2320f!2m2!1d-82.7116821!2d41.4561754!3e0
edited 01/10/21 02:49pm by an administrator/moderator *
Edd505
Elephant Butte, NM
Interesting route, I grew up in WI and forget about the UP. Have to put that on my to do list, been way too many years and the UP is beautiful.
Ferry WI to MI]Ferry WI to MI
edited 01/10/21 02:50pm by an administrator/moderator *
