RV.Net Open Roads Forum: Do NOT use Flex Seal on your camper roof!
 > Do NOT use Flex Seal on your camper roof!
Seminoe Joe
Texas, Wyoming, or somewhere in between
Posted: 01/09/21 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Figured I’d post this since I had a troubling conversation with my repair guy a couple weeks back when I picked up my camper after it was repaired following a minor collision last fall. We were discussing my long battle with a skylight leak in the bathroom and I mentioned that at one point I used flex seal spray as an emergency measure until I could do a proper repair with new butyl tape and Dicor and eternabond. He got all exited and told me that the “flex seal is great stuff! That’s the way to go!” And he used it on his parents’ leaky shed roof and its holding just fine. I nodded and told him it’s great for an emergency but from my firsthand experience, it becomes brittle, cracks, and eventually peels off when it’s been exposed to ultraviolet light for more than a few weeks. He apparently wasn’t aware of that. Ive been thinking about that conversation for a few weeks now and figured I’d post a thread about it to inform others who might be tempted to use flex seal as a permanent solution on camper roofs. DON’T!
Even though the tv commercial shows a guy sealing a skylight,
Even though your repair guy or dealer might tell you it’s great,
Even though a website or blog extols it’s virtues,
It is NOT a permanent solution!!!!! Emergency patch? Sure. But it WILL become brittle, crack, and peel off in a few weeks under UV light (sunlight).
So please, PLEASE, don’t even think about using this stuff I place of lap sealant or eternabond.
This has been a public service announcement.
We now return to your regularly scheduled program.
“It’s all in the reflexes.”
2012 Lance 850
2012 Chevy 2500 HD
BurbMan
Noblesville, IN
Posted: 01/09/21 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
It works great but is not UV rated. Use it on the underbelly or in a shady location and it holds up just fine, not in the sunlight tho...
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Williams AZ area
Posted: 01/09/21 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a quart of Heng’s and roll Eternabond on my travels.
specta
utah
Posted: 01/09/21 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Kenny
2011 Chevy 2500 HD 6.0L 4wd
newman fulltimer
louisiana
Posted: 01/09/21 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Guess he saw money signs When people call me and say they used it i say good luck i dont want any part of it
Fisherman
Angus, Ontario, Canada
Posted: 01/09/21 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Well I'm on the other side of the equation. I used the Flex seal caulking tubes to seal up a couple of cracks in the roof in the spring. It stayed tacky for about 2 weeks and then became less and less tacky as time went by. Fast forward to fall, after checking a number of times, it didn't crack, peel become brittle or shrink and the trailer rood has full sun exposure for at least 6-7 hours a day.
cavie
Posted: 01/09/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
deltabravo
Spokane, WA
Posted: 01/10/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
This is what I did when I wss bored last summer after I found an old tube of Dicor
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Kayteg1
California > Nevada
Posted: 01/10/21 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I bought my Fleetwood with roof damage, where the seller bothered the repair with eterna bond tape.
Was fighting the leaks for 3 years as no caulk would hold for long time.
I tried expensive marine caulks, RV caulks and top-grade construction caulks and none of them would stick permanently to my rubber roof.
Finally the Henry Tropi-cool roof sealer come on the market and after trying it on my house roof, I put it on my camper.
That coat sealed everything solid, regardless if the caulk under was holding better and worse.
It is self-leveling coat, so nice finish and the only problem was avoiding running on tilted camper nose.
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 01/10/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
I agree about Flex Seal being a VERY temporary fix. I used it on a leaky sunroom roof (on our Snowbird condo) - it worked for a month, then the Florida sun just seemed to vaporize it. When we returned the following fall, the roof leaked just as badly and when I climbed up to look at it - there was NO sign that I had ever tried to seal the leaks :-( Fortunately, I hadn't left any furniture in the sunroom because it would have been a moldy mess....
There was one patch that I had made previously, using Eternabond tape - and that was still holding very well.
