RV.Net Open Roads Forum: Tech Issues: Reviving flooded deep cycles
 > Reviving flooded deep cycles
wopachop
Who run bartertown
Posted: 01/11/21 12:07am Link  |  Quote  |  Print  |  Notify Moderator
wopachop
Who run bartertown
Posted: 01/11/21 12:08am Link  |  Quote  |  Print  |  Notify Moderator
wopachop
Who run bartertown
Posted: 01/11/21 12:12am Link  |  Quote  |  Print  |  Notify Moderator
11pm almost forget to take my fancy charger inside!! Happened the other night. Had to check security cams to determine morning dew. Walk me out, in the morning dew, my honey.
wopachop
Who run bartertown
Posted: 01/11/21 12:18am Link  |  Quote  |  Print  |  Notify Moderator
Never seen this before. Look at those youngsters!!
https://www.youtube.com/watch?v=fpKQOvlDr-s
philh
Belleville MI
Posted: 01/11/21 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
I built a charging circuit that would at least partially revive a lead acid battery. Pitched it with a whole bunch of other junk. Simple circuit, large cap, bridge and power switch
grizzzman
salt lake city, Utah
Posted: 01/11/21 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
wopachop wrote:
Does it turn open circuit because of a mechanical failure? Or does the chemistry flip back and forth?
It's strange how my charger voltage display will turn on and off, just as if the battery was a switch and turning on and off. Just seems like a mechanical failure would be permanent. So I dont think it's that.
Then you have never seen an internal strap connection "lift off" (go open) then cool and reconnect then. It happens.
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH Hybrid. TS60 Morningstar SCC.Renolagy DC to DC charger. 2000 Watt Inverter.
Boondocking is my Deal
