RV.Net Open Roads Forum: Class C Motorhomes: Best tire inflator for dually tires
 > Best tire inflator for dually tires
jimbo4UT
Stafford Virginia
Posted: 01/10/21 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Funny what I paid for my inflator I could buy 4 with your priced inflator and put one each tire. Lol ??
Jimbo
jimbo4UT
Stafford Virginia
Posted: 01/10/21 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Correct and I just ordered Teflon tape plus propane tape as I have a small leak so might as well tape it up too
pnichols
The Other California
Posted: 01/10/21 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
MDKMDK
Lockdown Gulag
Posted: 01/10/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
Jimbo
Many folks like the VIAIR inflators. Most say they're great, and I would hope so, considering the price tag.
I got a Fini 120PSI 2 gallon hot dog compressor at Menards for US$80 on sale. I then mosied over to Harbor Freight and bought the fixin's for it, a couple of brass quick connect fittings, some high pressure air hose, and an air chuck that reaches my inside dual rear valve stems. Total, maybe US$35? Like yours, the Fini is 110AC so if necessary, I can fire up the generator, and plug in. Or use it in the driveway at home.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
ORbiker
Springfield, Oregon
Posted: 01/10/21 09:31pm Link  |  Quote  |  Print  |  Notify Moderator
I put the ( LINK )Crossfire Dual Tire Pressure Equalization System on my Ram dually. Works great.
Backpacker and tent camper all my life. Motorcycle trips with a tent too 1978 to Present. 2016 Grand Design 380TH as of 10-29-2015. Now a New 2018 374TH-R Solitude as of 3-16-19. 10-19-18-traded truck for a 2016 Ram 3500 DRW Laramie Crew Cab 4x4 Long Box.
Harvey51
Alberta
Posted: 01/10/21 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I used the Milton inflator tool on the right for a couple of years until it started leaking air.
Note the post in the business end: it tends to slip away from the Center of the opening for the tire valve and fail to open it - allowing the compressed air to leak away. There is a black rubber ring that is supposed to hold the post in the center that seems to be worn out.
I went back to the same store to complain and they sold me an identical new one. Stupid. It leaked, too. Same problem. Turning the slotted business end gives access to the rubber ring so it could be replaced if I could find or make one of the right size I could make it work again.
I bought a new DILL USA from another store which worked. It works well new and hopefully will last for a longer time.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
jimbo4UT
Stafford Virginia
Posted: 01/11/21 05:25am Link  |  Quote  |  Print  |  Notify Moderator
to be very honest with everyone I do not check my air pressure very often. My motorhome is brand new and wanted to make sure it was up to correct pressure on all the tires. Unless i am headed out to extreme heat area's I wont check it period, same as i do my car. Some people check it every time they go somewhere but we are full-timers (second go around) so that would mean everyday doing it and I just do not see the point. Now i will have many come on here and say oh i felt the same way but after a tire tore the bottom side of my trailer/coach I think differently. Go to a truck stop and get a tire checker ( I used to work at a truck stop) it looks like a small baseball bat with a metal band around the top. You simply wack the tire and it makes a sound when it is full and a totally different sound when under inflated or flat. So in reality i do check the tires often just not with a gauge. Flame away.
Jimbo
bobndot
Posted: 01/11/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
NRALIFR wrote:
I think this is the best inflator and accessories I’ve ever had. The compressor is auto-shutoff, meaning you can use closed air chucks just like a real compressor, and it will shutoff when the hose pressurizes to the cutoff pressure. The dually extension is very well designed, and is all I use to inflate my truck tires. It comes with enough hose to reach your trailer tires as well. Yeah, it’s not cheap. Buy once, cry once.
Viair 400P-RV
[emoticon][emoticon]
X2. Yes expensive , but it works and thats what i need being a boondocker 20 miles from a paved road.
Very powerful. Its the best i have ever used. Parts of it get very hot, let it cool off for a couple of minutes before you pack it up.
Dusty R
Charlotte Michigan 48813
Posted: 01/11/21 07:29am Link  |  Quote  |  Print  |  Notify Moderator
We tow a tandem axel flat bed trailer taking our antique tractor to shows. One I got the trailer out and check the tires with a pressure gauge, they were OK, and I loaded my tractor. It was a few hours later before we left. Then we stopped at a grocer store and while my wife went in I checked the load, and found a soft tire. Apparently checking the air caused a valve to start leaking.
So now I only check tires with a radiant thermometer.
Dusty
jimbo4UT
Stafford Virginia
Posted: 01/11/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Thank u ?? you made my case for those who overcheck everything.
