mkirsch
Rochester, NY
I came out this morning and the left tire on my utility trailer was dead flat. Just came back from a 260 mile round trip, and it was up and fine when I went to bed last night.
The valve stem failed catastrophically during the night. Glad it didn't happen on the road.
Would the tire have sustained any damage from just going flat in the driveway? Tire is only 2 years old.
Bumpyroad
Virginia
was the trailer loaded? what amount of pressure would be applied to that tire when flat?
bumpy
pitch
NY
I wouldn't worry about it.
BobsYourUncle
Calgary Alberta Canada
Not if you didn't move it while flat.
Jack it up, remove wheel and get it fixed.
You will be 100% ok
(Was it a 10 ply tire? Your sig.)
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
mkirsch
Rochester, NY
BobsYourUncle wrote: (Was it a 10 ply tire? Your sig.)
![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Load range D, so 8-ply actually...
BurbMan
Islip, Long Island
If you don't have hi-pressure valve stems you should replace the other one too before it meets a similar fate....had that happened going down the road the tire would have been toast and possibly the rim too.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
mbopp
Henrietta, NY, USA
While you're at it, replace the valve on the other tire also.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
mkirsch
Rochester, NY
mbopp wrote: While you're at it, replace the valve on the other tire also.
Excellent idea.
valhalla360
No paticular place.
mkirsch wrote: BobsYourUncle wrote: (Was it a 10 ply tire? Your sig.)
For starters, I would stop buying antique tires built up with multiple cotton plys. ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif)
No it shouldn't have hurt anything if it just deflated while sitting.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
CapriRacer
Somewhere in the US
mkirsch wrote: I came out this morning and the left tire on my utility trailer was dead flat. Just came back from a 260 mile round trip, and it was up and fine when I went to bed last night.
The risk here is that there may be damage inside. The safe thing to do is replace the tire.
If you reinflate the tire (do this carefully!!) and see sidewall ripples, replace the tire.
If you reinflate the tire and don't see sidewall ripples, that doesn't mean the tire is good. It means you don't know!
CapriRacer
Visit my web site: www.BarrysTireTech.com
