RV.Net Open Roads Forum: Tech Issues: Checking voltage on LED power supply ?
 > Checking voltage on LED power supply ?
JoeH
Apollo Beach,FL
Posted: 01/11/21 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Not RV related per se, but figured someone here would know. I recently purchased a set of LED lights to put some path lights to avoid tripping. Hooked up the lights and everything works fine.
Next, I decided to put a strip of 5050 led's on some stairs. The strip LED's have + and - markings and are 12v . The output from the power supply for the path lights is also 12v so I figured I'd hook into that. I got out the meter and I get nothing when I check the voltage, yet the lights work. Check the meter with a different power supply I have for some other lights and it reads 12v as it should. So, why would the new power supply indicate no voltage and yet at the same time, successfully light up the 12v LED lights?
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
jkwilson
Indiana
Posted: 01/11/21 07:48am Link  |  Quote  |  Print  |  Notify Moderator
AC or DC?
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
enblethen
Moses Lake, WA
Posted: 01/11/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Reverse your meter leads may show voltage.
It could also be the way diodes are placed in the circuit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Tom_M
New Hope, MN
Posted: 01/11/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Switch your meter to AC and check. Most likely one supply is AC and the other is DC.
Tom
2005 Born Free 24RB
Towing 1978 VW Bug convertible
Minneapolis, MN
wopachop
Who run bartertown
Posted: 01/11/21 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Conformal coating.
I didnt exactly understand your entire post but type that into Google.
JoeH
Apollo Beach,FL
Posted: 01/12/21 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Nope-- meter stays on "0" regardless of being on AC or DC.... but the LED lights out in the yard work. Strange
Gdetrailer
PA
Posted: 01/12/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Post a pix of the power supply with the model number..
I suspect it is a high frequency switching supply and has no or little filtering on the output.. Most meters will not read at all or properly 15Khz-30khz frequencies which most switching supplies operate at which could explain why you can't get a reading but the lights work.
JoeH
Apollo Beach,FL
Posted: 01/14/21 06:03am Link  |  Quote  |  Print  |  Notify Moderator
I'll get a pic soon---- sounds like you might have solved it.
jkwilson
Indiana
Posted: 01/14/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Even with poor filtration, the output of a switch-mode supply is still DC and could be measured with any DC volt meter.
JoeH
Apollo Beach,FL
Posted: 01/14/21 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Quit raining and I went out to get a pic-- it is AC output but no reading on meter.
* This post was edited 01/14/21 11:14am by JoeH *
