I am Yu
I'm running on internal water (not city water). I don't leave the water heater turned on all the time (too wasteful to do so) and when I turn it on it raises the pressure in the whole plumbing system way too high, and I get water leaking from the toilet onto the bathroom floor. The only way I've found to deal with this is to shut off the pump and briefly open a faucet every 10 minutes to relieve the pressure, until the heater gets hot and the pressure stabilizes, which gets pretty annoying.
There is a pressure relief valve on the water heater, but apparently it's only intended to protect the heater tank, and opens at too high a pressure to do anything for the plastic plumbing.
Is there some kind of relief valve that opens at a lower pressure, which I could install somewhere in the system and have it drain overboard?
2oldman
south
I have the same issue. I turn off the pump and leave a HW tap open. When the tap starts to drip I turn off the heater.
Sjm9911
New Jersey
Intresting problum, maybe try to turn down the tempature of the water heater. Less heat , less expansion , less pressure, maybe.....just an idea.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Boon Docker
Sounds like a faulty check valve on the cold water line at the water heater.
Dusty R
Charlotte Michigan 48813
I like installing a small bladder type pressure tank. It makes the whole water system work nicer.
Lynnmor
Red Lion
Drain the water heater and refill it, that will re-establish the air pocket in the tank and allow for expansion. See your water heater owners manual for more information.
schlep1967
Harrisburg, PA
Lynnmor wrote: Drain the water heater and refill it, that will re-establish the air pocket in the tank and allow for expansion. See your water heater owners manual for more information.
Or just turn off the pump and drain a small amount out. Then turn the pump back on without using 6-10 gallons of water.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
time2roll
A small accumulator will solve the issue. Yes I had the same problem.
Amazon - Shurflo 181-201 Accumulator Tank $38
This creates a permanent air pocket.
Mine was in the RV shop twice for several weeks for a mystery water leak. Never found. I had to dig for this myself while camping. I guess the dealer did not think to cycle the water heater to find a leak.
edited 01/12/21 11:14am by time2roll *
675w Solar pictures back up
4x4van
California
/\ This /\
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
Lynnmor
Red Lion
schlep1967 wrote: Lynnmor wrote: Drain the water heater and refill it, that will re-establish the air pocket in the tank and allow for expansion. See your water heater owners manual for more information.
I didn't want to get onto it, but since the air dissolved into the water tells me that draining and flushing is way overdue.
