RV.Net Open Roads Forum: Truck Campers: Ram 3500 with factory airbags
 > Ram 3500 with factory airbags
rhagfo
Portland, OR
Posted: 01/12/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
So one more post to add clarity.
The 1st gen of the Ram Air Suspension came out in 2013 or 2014 and looked like the picture below.
Then in 2018 they appear to have made changes to make the addition of the Air Suspension a easier process. Now instead of having to add a bracket to the frame for the upper link arm, now it all goes in the leaf spring brackets. Now there are basically traction bars under the single leaf to prevent axle wrap. That bar only goes forward of the axle.
towpro
Compass PA
Posted: 01/12/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
towpro wrote:
lots of replies on here have never seen the ram air suspension. .
Neither did you.
It doesn't exist.
why do you need to treat people like this?
Maybe its time you give the internet a rest?
PS: Here is the name right out of the place you order the "automatic level-rear air suspension
* This post was edited 01/12/21 05:49pm by towpro *
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
bwlyon
64633
Posted: 01/12/21 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
You’re overthinking. The Ram air suspension is doing exactly what is supposed to do. If you want your suspension to sit a little lower use the Alt Ride Height button. Otherwise, don’t worry about it.
HMS Beagle
Napa, California
Posted: 01/13/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
The RAM air suspension is certainly not full air suspension as you might see on a semi. Many differences starting with the semi-elliptic spring to locate the axle.
But I'd agree that the thing being called an "overload" is actually intended to prevent axle wrap, not carry any load. That system will also have some problems with torque jacking of the suspension - they should have stuck with and refined their first attempt. Or better still, licensed the system from Autoflex, who solved this problem (how to easily install true air suspension with no frame mods).
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Gary Morency
windsor ontario
Posted: 01/14/21 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
You can buy thicker bumpstops and they will take up the space your talking about I installed them on my 18 and they help a lot with sway but give you a harder ride empty. That space we have with the factory ones is there for that reason. I just remove them when the camper isn;t going to be used for a while.
