RV.Net Open Roads Forum: Tow Vehicles: HITCH HEIGHTH ?
Search only in Tow Vehicles
 > HITCH HEIGHTH ?
Oasisbob
Portland Oregon 97266
Posted: 01/11/21 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I am installing my old class 3 adjustable heighth hitch on my new to me Ford Explorer with factory receiver. On the lowest setting my ball is still 2-3 inch's taller than my trailer hitch is when trailer is level. This is unhooked. Do you think my Explorer with factory tow package will sink down a few inch's and work? I do use load leveling bars. Option B is to purchase a different hitch that will lower the ball another two inch's. What say you? I know for sure you guys know more than I do. Thanks in advance.
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
agesilaus
North Florida
Posted: 01/11/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hook it up and check it. You have a WDH and that doesn't have it's own receiver?
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Quartzsite, AZ
Posted: 01/11/21 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
You want your Explorer to squat 2 or 3 inches so you don’t need a new hitch?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bigorange
Tucson, AZ
Posted: 01/11/21 10:37pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t think any of us know your setup like you do...and the best way to find out is to hook it up and give it a try.
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
Posted: 01/12/21 12:08am Link  |  Quote  |  Print  |  Notify Moderator
Congrats on the new rig Bob!
Sounds like it’s close to working.
Couple things?
Is the Explorer auto level air ride? If it is, that doesn’t help, but it may not be prohibitive.
Is your trailer tandem leaf springs? If so it will handle a little nose up better than torsion axles which will place more load on one axle or the other if not close to level.
Lastly, throw the trailer on, put some weight in the vehicle and camper to simulate how it will be loaded on the rear axle of the vehicle. See how it looks and drives restoring some weight to the front as needed.
If it’s good, it’s good. If not, then you may need to get a lower hitch.
Imo, I’d confirm that first. If no auto level I bet it will be very close or work.
2017 Heartland Torque T29
ronharmless
The far side
Posted: 01/12/21 05:12am Link  |  Quote  |  Print  |  Notify Moderator
Yes it's going to squat some, but you won't know how much until you try it. An inch or two one way or the other is not the end of the world.
kellem
Shenandoah valley,VA
Posted: 01/12/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
If your using a WDH you'll want to take 2 measurements of the front end of tow vehicle, ground to wheel well.
Take a measurement unloaded and another with trailer hooked up with tounge weight.
Set the hitch up to where the 2 measurements have been split. This indicates weight transfer.
That said, with my HD trucks, I've always started with my hitch ball 1" higher than trailer coupler when setting up WDH and always got weight transfer and a level trailer.
Not knowing your trailer or tow vehicles capacity, none of what I said may happen.
Geo*Boy
Unknown
Posted: 01/12/21 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Bob, get a B&W Tow N Stow and adjust accordingly.
Oasisbob
Posted: 01/12/21 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. Some good observations. Seems I just need to hook up and see. Thursday looks dry . I will let ya all know. Thanks again
Posted: 01/13/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
^ Now lets see a pic of the new Explorer! Eco boost?
 > HITCH HEIGHTH ?
