waitingtogo
central texas
I Am driving to Houston to look at a 2004 Damon Challenger 348 vortec tonight. Any opinions good or bad. thanks
near Bishop, California
Seventeen years old. Maintenance records complete? Tire ages?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Rick Jay
Greater Springfield area, MA
Probably the most important thing is to check for water leaks inside. If evidence exists, probably good to pass this one by unless you're 100% sure the problem was dealt with promptly and solved.
Make sure the floor plan is what you want.
If they have maintenance records, that's always a plus.
By "vortec" I'm assuming it's on the Workhorse W-22 (22,000 lb. GVWR) . If it's on the W-20 (20,700 lb. GVWR), that might be a bit light for a 34' motorhome. The Workhorse units came with an Allison transmission, which is a HUGE plus over the Ford offerings at the time. Workhorse chassis were not as common because they had an upcharge of between $3k-$5k over the Fords at the time. In my opinion, the Workhorse was a better chassis at the time, as evidenced by the rig in my signature! :-)
If it has slides & levelers, make sure they work as they are supposed to.
Most other things can be replaced or fixed. It's not new, it's 16 years old, so judge it accordingly.
Can't say much about Damon as a manufacturer. My uncle had one, a late 1990's model Class A, and he mostly spoke highly of the rig. The old Ford chassis left him wanting on hills and maneuverability, but the house part was pretty good.
Good Luck, let us know what you found.
~Rick
edited 01/13/21 06:54am by Rick Jay *
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (24-Angel since 2008), 1 girl (19), 2 boys (20 & 17).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
waitingtogo
central texas
thank you. i just found out it is a 2003. i will ask about the allison.
crawford
Dandridge Tenn.
Check see if this has true park if not run away. My brother had one looked like a air brake switch that was park problems of many.
Change from a c class to a A class Georgetown 07 triple slide
ArchHoagland
Clovis, CA, USA
waitingtogo wrote: I Am driving to Houston to look at a 2004 Damon Challenger 348 vortec tonight. Any opinions good or bad. thanks
Well...did you buy it?
Inquiring minds would like to know.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
