RV.Net Open Roads Forum: General RVing Issues: Oil rubbed bronze Handheld Showerhead
 > Oil rubbed bronze Handheld Showerhead
TenOC
On the road -- Full time
Posted: 01/12/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
The new to us 5th wheel came with a less than desirable showerhead. The “handheld” showerhead is on an adjustable vertical pipe to raise the height, and is what I think is called oil rubbed bronze.
We dry camp often; thus, I am looking for showerhead that does not use a lot of water. I have looked at Lowe’s and also online and there are a wide variety of bronze showerheads.
A number of you have suggested an Oxygeneics showerhead in previous postings. Oxygeneics makes a wide variety of showerheads but very few oil rubbed bronze.
I am looking for real life recommendation. Thank you.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
craig7h
Branson MO area
Posted: 01/13/21 04:13am Link  |  Quote  |  Print  |  Notify Moderator
To me the Oxygenics 26488 BodySpa RV Handheld Shower is the best. I have put it in my past 3 RVs and have no complaints. Water pressure is great vs. water usage. For you however it only comes in chrome and white. I think you are going to have to make a choice.
Itasca Meridian SE 36g
Road Master Tow Dolly
Dick_B
Palos Heights, IL USA
Posted: 01/13/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Many showerheads have a restrictor built in that controls the water flow to a government accepted rate. It looks like a washer with a small hole in it. If you can find that restrictor maybe there is a way to duplicate it with a smaller hole.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Sjm9911
New Jersey
Posted: 01/13/21 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I think the main diffrence with an rv style one is the abillity to turn it off at the showerhead so you dont waste water. You will not get that with a water restricter or at a box store. They are correct on the oxagenics ones even though i went with a knock off brand. If you are saving water, you need an rv type showerhead.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
TenOC
Posted: 01/13/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
What knockoff brand did you purchase? Are you happy?
Posted: 01/13/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
You could always take apart the shower head and block off part of the flow at the screen. A little epoxy or glue and allow less flow through.
$0 low flow shower!
2017 Heartland Torque T29
Sjm9911
New Jersey
Posted: 01/13/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Its a cheapo one, its not great. But it beats filling up the gray tank when the 9 yo is in the shower. Lol. Ill look to see what i got.
Sjm9911
New Jersey
Posted: 01/13/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/gp/aw/d/B0713MVT1M?psc=1&ref=ppx_pop_mob_b_asin_title
Before the covid we didn't use the shower in the camper much, but now its all we use when we go out. Like i said a chepo. Im sure you can find something that works on amazon. If its **** return it.
soon2bexpat
roaming the South West
Posted: 01/13/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
I went to the link provided for the cheapo showerhead and see that it's the one I bought in 8/17. Still going strong and I full-time, so can recommend it. Not sure how it compares to water usage compared to the oxygenics, though.
Kodachrome Time Machine, my vintage photo collection from the 1940s to the 1970s: https://www.youtube.com/channel/UCff0z54NyAfuAjUST896l6g
Lenny K
Vancouver Island or Quartzsite
Posted: 01/14/21 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I have the rubbed bronze shower fixtures and when I replaced the shower head with the Oxygenics I simply found some plastic spray paint to match. Make sure you clean the Oxygenics with alcohol good to remove any oil residues before spraying. Ours still looks good after 5 years.
Lenny and Ros
2009 Chevrolet Silverado 3500 LTZ Duramax 4x4 CC Dually, Banks Speed Brake
2012 Montana 3400 RL 680 Watts Solar, 440 Amps of Batteries, GP-ISW2000-12 Inverter, Trimetric 2020, EMSHW50C, Sailun Tires
