RV.Net Open Roads Forum: Tech Issues: troubleshooting a propane range oven pilot
 > troubleshooting a propane range oven pilot
geoffash
Newfoundland
Posted: 01/13/21 07:10am Link  |  Quote  |  Print  |  Notify Moderator
So...this isn't really an RV specific question, as I've turned my TT into essentially a permanent tiny home, but I figured this was a good a place as any for a general knowledge base on propane appliances.
I swapped in an older model 20" Danby range - D545 W - which I cannot find any info for online, except for a handwritten pdf parts list. Called Danby, they were no help.
It's completely propane, no electrical connections.
The issue I'm having is that the oven has become very finicky, which I've narrowed down to either an issue with the heater pilot or the oven control dial itself.
It used to be that when I turned the dial to "oven", the heater pilot would engage to heat the thermocouple, so I'd leave it there for a minute or so, turn it to the desired temp and the oven burner would light.
Now the heater pilot doesn't engage until the oven dial is turned to 170, then the burner won't light unless the dial is then turned up to "Broil", and takes about 5 min.
The heater pilot is definitely not hitting the end of the thermocouple in it's current setting.
By turning the only adjustment screw I can find (on the oven dial mechanism) I can turn up the heater pilot, and the oven lights within 30s which leads me to believe the thermocouple itself is fine. However...I can't find a setting on that screw which will increase the burner pilot without the standing pilot going out once the oven is turned off. Some pics of the oven dial and mechanism, and pilot assembly. Any suggestions would be appreciated.
thanks
https://drive.google.com/file/d/14EyRVGgjVUH9oZwqO-7f-f25yQGOBrC9/view?usp=sharing
https://drive.google.com/file/d/18FZzZtLQy82XP8KGkShWfRl5qwfSnudz/view?usp=sharing
https://drive.google.com/file/d/1jO4PpzzA7aTQgEquYBeJpqRlaAbo5GVd/view?usp=sharing
Bessie-Hunter
Frostproof, FL
Posted: 01/13/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
The screw your turning converts the pilot setting from Nat gas to LP. Leave it on LP. Disassemble the pilot assembly and clean the orifice and the entire pilot assembly. The screw on the pilot line on the back side of the valve is the adjustment for the high pilot adjustment.
Old-Biscuit
Verde Valley
Posted: 01/13/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Totally agree^^^^^^^^^^
One other point
That 'spreader plate assembly' for pilot flame...it appears to be pointing pilot flame onto 'barrel' of thermocouple not the tip and in that position is short of the pilot flame ignition slot for main burner flame
Has it been moved...can it be moved???
